Old 09-30-2020, 06:54 PM   #1
Daba
Default Carburetor backfire
I have a 31 three window four-door with a B motor the car runs great up until 45 miles an hour anything over 45 it starts to pop through the carburetor any suggestions would be grateful. Carburetor adjustment? Timing adjustment? fuel mixture adjustment? drive the car off a cliff ?? Lol
Thanks again Daba
31 three window four-door deluxe with B motor
31 slant window four-door deluxe
Daba is offline   Reply With Quote
Old 09-30-2020, 08:39 PM   #2
GRutter
GRutter's Avatar
Default Re: Carburetor backfire
I would check point gap setting to be sure that there is enough dwell angle to allow coil to build back it's field.
As point rubbing block wears, the points ride closer to the cam, holding them open too long. Then as speed increases, you get to a point where the points are not closed long enough to build up a full field in the coil. A weak spark results.
GRutter is offline   Reply With Quote
Old 09-30-2020, 10:34 PM   #3
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
It sounds lean to me. Have you opened up the GAV when it starts popping to see if it runs a little better? Be sure to let us know what the solution is.
Have you played with the timing recently?
Old 10-01-2020, 12:45 AM   #4
Certimafied
Certimafied's Avatar
I would guess lean mixture as Chuck Sea/Tac said or timing is off for that engine rpm and load.
I recently had a Porsche ( I know way different beast hear me out though) that had some surging and backfiring problems at cruising speed . I ended up finding the intake valves way too tight and a series of small vacuum leaks. Adjusting the valves cleared up a lot of issue and fixing the vacuum leaks cleared up the rest.
Certimafied is offline   Reply With Quote
Old 10-01-2020, 03:06 AM   #5
johnbuckley
johnbuckley's Avatar
yep often a symptom of a weak mixture/fuel starvation, ... so easy things first ... check the flow of fuel from tank to carb and the various stariners filters etc.. then move on to other stuff.
Old 10-01-2020, 06:22 AM   #6
Daba
I’ll give the GAV a shot today and check back. Can I use the new timing wrench I got for my other model A on a model B engine ?
Old 10-01-2020, 06:46 AM   #7
John
John's Avatar
It sounds like it is time to get that 'B' carburetor cleaned out.
John is offline   Reply With Quote
Old 10-01-2020, 06:52 AM   #8
Patrick L.
Patrick L.'s Avatar
Good info, but, loosen the fuel cap and take it for a drive. The vents are known to plug.
Old 10-01-2020, 08:36 AM   #9
rocket1
Intake valve hanging up try MMO in the gas tank.
rocket1 is offline   Reply With Quote
Old 10-01-2020, 11:06 AM   #10
johnbuckley
Yes, Thanks Patrick.. I'd forgotten about that one ..... That's another one that has caught me out!
Old 10-01-2020, 11:58 AM   #11
Patrick L.
Patrick L.'s Avatar
John, with our age and what we have rolling around between our ears its easy to forget where we put all that info in that grey matter.
Old 10-01-2020, 03:37 PM   #12
Daba
I tried the gav no difference then the timing much worse. I used the New timing wrench I got for the model a apparently the timing is slightly different. It moved about a quarter of a turn more than it was to start I think I’m going to go back to that point and try again.
Old 10-01-2020, 06:08 PM   #13
Daba
I opened up the points and BINGO it did the trick. Thanks again for all your suggestions.
Daba
Old 10-01-2020, 09:25 PM   #14
GRutter
GRutter's Avatar
Glad to see that fixed it for you.
George
Old 10-02-2020, 03:28 PM   #15
shew01
shew01's Avatar
George
Love the graphic. Yup, I’ve definitely had that feeling after finally getting the car to start when it was broken in the past. [emoji23]
