Old 09-05-2019, 05:56 PM   #1
Clem Clement
Clem Clement's Avatar
Default electric gas pump on a 39 PU Frame
I'm adding a electric fuel pump. Mount it on the bottom flange of the frame away from the electric wires and forward the rubber spring bumper?
Clem Clement is offline   Reply With Quote
Old 09-05-2019, 07:42 PM   #2
JSeery
JSeery's Avatar
Default Re: electric gas pump on a 39 PU Frame
About anywhere that is convenient close to the tank. Some pumps make a bit of noise, might want to mount it on some type of rubber isolator if that concerns you. Also normally want a filter on the inlet side of the pump.
Old 09-05-2019, 08:07 PM   #3
skidmarks
skidmarks's Avatar
I make a bracket and mount them to the top of the rear crossmember were it's easy to access and plumb up. Perfer not to use rubber hose.
skidmarks is offline   Reply With Quote
Old 09-05-2019, 08:52 PM   #4
Clem Clement
thanks
Old 09-05-2019, 10:01 PM   #5
38bill
38bill's Avatar
I mounted mine on the rear crossmember just left of the tank. I used a rubber mounting pad and used short rubber fuel lines at the pumps inlet and outlet to connect with the metal lines. I think the rubber line keeps the noise from amplifying through the frame and fuel lines. It also make it easier to change the inline fuel filter.
38bill is offline   Reply With Quote
Old 09-05-2019, 11:39 PM   #6
50fordcoupeman
50fordcoupeman's Avatar
I also added a fuel shut off valve just out of the tank. Nice to shut off the gas supply while changing the filter.
50fordcoupeman is offline   Reply With Quote
Old 09-06-2019, 01:11 PM   #7
drolston
drolston's Avatar
I mounted mine inside the frame rail just in front of the left rear wheel. Be sure to include a filter. I connected mine with rubber fuel line, including a "service loop" both behind and in front of the pump to make the pump or filter easier to replace. The extra length of rubber fuel line also makes it easier to seal off both ends using clamps or vice grips instead of a valve, which is just another thing to leak or get stuck.
Old 09-06-2019, 02:24 PM   #8
skidmarks
skidmarks's Avatar
The reason I avoid rubber hose, modern gas. I have had a number of deteriorated hose that wasnt that old.
If you use hose find the best quality available and keep an eye on it.
Old 09-06-2019, 04:38 PM   #9
drolston
drolston's Avatar
Amen. Any sign of softness or swelling, replace with the best stuff available, certified for use with gasohol.
Old 09-07-2019, 12:38 PM   #10
FireEngineMike
FireEngineMike's Avatar
You can buy hose that meets all standards for ethanol fuel that is designed for carb engines. No need to spend extra for FI rated hose. I bought gates hose from rock auto with the fuel filter order.
FireEngineMike is offline   Reply With Quote
