12-01-2017, 04:29 PM | #1 |
1931 Instrument panel light
Does anyone restore them? I have several original ones that i would like to restore, does anyone here have any information about the process, or a clue as to where i can find an article or reference on them.
12-03-2017, 08:15 PM | #2 |
Re: 1931 Instrument panel light
This doesn't answer your question, but it will at least bring the question back to the top.
If you are running 6 volts and would like a less bright and hot instrument panel light, try a 12 volt #63 bulb. This information courtesy of Jim Cannon. |
12-03-2017, 08:27 PM | #3 |
Most suppliers carry new ones.
12-04-2017, 12:09 AM | #4 |
These are just a simple mechanical lamp, what is the problem you are trying to fix?
12-04-2017, 12:13 AM | #5 |
Kust installed an original in mine, only restoration needed was a bulb
12-04-2017, 10:44 AM | #6 |
Bill Seeingspots
