Old 12-25-2016, 09:33 PM   #1
4tcoupe
Default '40 Ford front fenders & king pin bearings
I am reassembling a "basket case" '40 coupe, the "V" support/brace between the front fenders that mounts to the center of the front X member with a spring & bolt/nut. Does the spring mount under the X member or on top of the brace? Also the load bearing, Ford script marked part #B-3123-A2, between the bottom of the front axle king pin boss and the spindle seems to be good. If I decide to replace it, are the available new ones good quality or junk? King pins & bushings seem good, no slop or wear.
Thanks, John
4tcoupe is offline   Reply With Quote
Old 12-26-2016, 10:26 AM   #2
glennpm
glennpm's Avatar
Default Re: '40 Ford front fenders & king pin bearings
Hi John,
The spring goes on top of the brace. This allows a little flexing and give to the connection.
This is wrong. The spring goes underneath the cross-member mount point.
Old 12-26-2016, 11:55 AM   #3
19Fordy
19Fordy's Avatar
Scroll down to post 197 and more for Y bracket install photos.
http://www.jalopyjournal.com/forum/t....949053/page-7
If all you need is the bearings make an offer on these with free shipping. At least with NOS you know it's American made from back in the day. MOOG no longer makes these. I don't think you can buy the bearings separately. Some kits come with thin shims to take up any wear. Some folks install roller bearing kit for "power steering" effect.
http://www.ebay.com/itm/1937-1938-19...RWz4aA&vxp=mtr
1/2 ton truck king pins and bushings are the same as a car.
Check here: http://www.droppedaxles.com/Kingpin_Part_Numbers.html.
Here's where you can get shims.
http://www.ebay.com/itm/Speedway-910...9VRUwc&vxp=mtr
