10-30-2011, 05:25 PM | #1 |
Cold cranking amp's for a V8
Looking to get a battery for the 39 and the battery that came with it was nice and short and about 550 CCA. Is this an average CCA for a flathead? Looked @ some short motorcraft's to keep the cables the short length they are now. Any input would be great.
10-30-2011, 05:43 PM | #2 |
Re: Cold cranking amp's for a V8
Scott, I learned yr's ago, I get the most cca batt that I can fit in my batt box. Walt
10-30-2011, 06:26 PM | #3 |
Scott, take my advise and get an optima,I had a big 6v lead acid one in my 33 and have just fitted a 6v optima, it spins it over great,I had to make a holder,but it is a lot smaller than the old lead acid type.
Lawrie |
10-30-2011, 07:36 PM | #4 |
I agree with you, Lawrie. He will be a happy man as the colder weather settles in up in Maine (or is it down in Maine?) Optima might be a bit more expensive, however, worth the investment. ..LouB.
10-30-2011, 08:10 PM | #5 |
I got a 6 volt Optima w/700 CCA. Using 00 cables and it's spins the starter pretty fast. Ken
10-30-2011, 09:54 PM | #6 |
Alan |
11-01-2011, 12:38 AM | #7 |
I want to try optima for my 50 shoebox with a 12v conversion. What optima would be the best ? I have a Mallory magnetic breakerless ignition as well. Don't Know much about optima and cranking amps, any help would be great.
"I have built my organisation on fear"..Al Capone. |
11-01-2011, 01:20 AM | #8 |
hombre, in my opinion, the Optima 6v is the best choice of all available 6v batteries. When it comes to 12v batteries, there are many more good choices. Of those, I like the Sears Diehard.
Alan |
11-01-2011, 09:50 AM | #9 |
So optima really don't make a good 12v battery?
11-01-2011, 11:01 AM | #10 |
Hombre, That's not exactly what I meant. I meant only that there are many 12v batteries to choose from, and I like the Diehard. Yes, I also have some Optima 12v batteries, and don't have problems with them.
Alan |
11-01-2011, 12:04 PM | #11 |
Thanks Alan. What optima would you recommend for the flathead .. Red top or yellow top. I want good cranking and starting
11-01-2011, 02:57 PM | #12 |
Red Top. Care for it by never using a fast charge, trickle charge, or battery tender. Use a 2 amp automatic shut off charger, the El Cheapo kind. Your Optima will love you for it.
Alan |
11-01-2011, 09:45 PM | #13 |
Does the optima always need a battery tender? Can you go without one?
11-02-2011, 01:09 AM | #14 |
No, I said do not use those things you use with a wet battery. You'll only need to charge it the first time, unless it is charged when you get it. Don't use any charger except a 2 amp auto shut-off.
Alan |
11-02-2011, 08:13 AM | #15 | |
to answer your question the old rule of thumb to cold cranking amps is 1 cca per cubic inch....if you have a 239 ci flathead you need at least 239...i prefer lead acid batteries that aren't permanently sealed....just my 2 cents...gump
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
11-02-2011, 09:04 AM | #16 |
I bet you could find someone that makes a plastic box that looks like an older 6 volt battery case that will hold the smaller Optima and will use the stock bolt down bracket.
