11-30-2018, 09:58 PM | #1 |
1932 Ford Model B seals
Replacing the front seals on my stock 32 Ford pickup, the ones that i purchased and that i think are called for are all metal, no rubber as in later model seals. The fit doesn't seem right, the inner ring of the metal seal presses tight on the bearing and it appears this may inhibit free spinning. The hub was disassembled when I got the truck and the original seal is not available. This is my first restoration project and i am having a great time, but stuck and have not been able to find much reference to bearing seals. any suggestions would be great. thanks Mike
11-30-2018, 10:06 PM | #2 |
Re: 1932 Ford Model B seals
Any pictures? If you put your general in your profile someone might be able to drop by and help or point you to someone that can help.
Does this help any: http://www.vanpeltsales.com/FH_web/F...wheel_to48.jpg ? The illustration is from the green Bible where you can find what the parts are based on the numbers shown. Charlie Stephens Last edited by Charlie Stephens; 11-30-2018 at 10:20 PM. |
11-30-2018, 11:31 PM | #3 |
There are no front wheel bearing seals in the traditional sense on '32-'34 Ford passenger cars and commercial vehicles; they weren't introduced until the '35 model year. The metal rings that you are referring to aren't seals at all, but rather primitive grease baffles and spacers for the inner wheel bearing. They normally do not impede the bearings' function.
12-01-2018, 12:30 AM | #4 |
Thank you for the quick response, the seals i installed seem to be just as you said baffles. After doing a considerable amount of research and reading your reply i am confident they are the right ones. i was concerned there was no clearance between the metal seal ring and the front of the bearing. i may be able to ease the baffle ring out a little and provide a small amount of clearance. Thanks again Mike
12-01-2018, 12:43 AM | #5 |
