Old 02-23-2018, 07:25 PM   #1
Ron Pilger
Ron Pilger's Avatar
Default 34 molding fabrication
I have not been able to stumble across a usable rear window molding or a driver's door (deluxe) molding for my 34 3 Window Coupe. To those of you who have fabricated either of these moldings using similar components from a donor 4-door sedan or Tudor, are you able to provide any advice or words of wisdom based on your effort? Thank you.
Ron Pilger is offline   Reply With Quote
Old 02-23-2018, 07:46 PM   #2
cas3
Default Re: 34 molding fabrication
i was under the impression all the rear windows are the same, not true?
Old 02-23-2018, 11:02 PM   #3
cas3
pm sent ron
Old 02-24-2018, 08:57 AM   #4
Bob/Pa
Bob/Pa's Avatar
3 and 5 rear windows same.
Bob/Pa is offline   Reply With Quote
Old 02-24-2018, 04:51 PM   #5
Barn Junk
Barn Junk's Avatar
Yes, Originals are hard to find nowadays. Steve's restorations in Portland OR, had repos made up for his repro bodies that he manufactured a number of years ago. Maybe he has some left. What I did years ago, in desperation, for 34 3-W door mouldings was to find a set of 34 2-dr deluxe fronts and a set of 34 4-dr sedan front door mouldings. Switched the 4dr mouldings to the opposite side/rear, cut off the back of the 2dr mouldings and trimmed, sectioned and relocated screw holes in the 4 dr pieces and fit/welded together. Luckily I borrowed some originals for patterns and everything turned out nice but a lot of work.
Barn Junk is offline   Reply With Quote
Old 02-24-2018, 06:50 PM   #6
Ron Pilger
Ron Pilger's Avatar
Steve's is no longer an option. I may try to find a fibreglass set to use as an interim measure. I have a full set of sedan moldings and one Tudor molding but am reluctant to chop these up, at this point.
Old 02-26-2018, 08:14 AM   #7
31aford
Try iversenorignals.com. They make new moldings.
31aford is offline   Reply With Quote
Old 02-26-2018, 12:38 PM   #8
Ron Pilger
Ron Pilger's Avatar
Thanks for the tip!
