Old 08-03-2017, 09:09 AM   #1
hbiehl
Default flathead 8 transmission question
I need a little guidance. I have a 8BA motor with a 9.5 clutch that I am putting in a 1953 f100. This motor did not come with the truck. The transmission is a T98-148 that did come with the truck. I discovered that the throwout bearing does not fit on the transmission. I need some guidance to what I should do next? What direction should I go?
hbiehl is offline   Reply With Quote
Old 08-03-2017, 09:25 AM   #2
19Fordy
19Fordy's Avatar
Default Re: flathead 8 transmission question
Sounds like you need to find out what throwout bearing you need. Get hold of a good parts/repair manual.
https://www.google.com/search?q=1953...hrome&ie=UTF-8
A 9.5 inch clutch is too small for an f-100. I believe it should be an 11 inch.
http://www.macsautoparts.com/ford_tr...earing&x=0&y=0
Old 08-03-2017, 09:37 AM   #3
George/Maine
George/Maine's Avatar
The 53 pu had a 10" and here is pic of 53 trans.
George/Maine is offline   Reply With Quote
Old 08-03-2017, 09:39 AM   #4
Ross F-1
Ross F-1's Avatar
Trucks all came with 10" or larger clutches, cars came with 9.5" and 9". Trucks also had larger diameter input shafts (1-3/8" vs 1-1/16", as I recall). You'll need to use a Truck clutch to mate the trans.
The correct throwout bearing is C0TZ-7580-B, or SKF N1087. The industry number is BIN 2065.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 08-03-2017, 09:46 AM   #5
blucar
blucar's Avatar
Generally speaking a T98 trans is a 4spd which would require an eleven inch clutch and therefore a HD throw out bearing.
You might want to check the pilot bearing in the crank shaft, it might be to small for the T98 input shaft.
Many years ago I purchased a 58 F100 that had a T98, the guy I bought it from was trying to put a newly rebuilt Y block V8 with a flywheel and clutch for a passenger car three speed. The truck had a T98 4spd. I replaced the flywheel/ clutch with one for a 4spd and the whole thing slipped right together..
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
Old 08-03-2017, 10:28 AM   #6
Ross F-1
Ross F-1's Avatar
Originally Posted by blucar View Post
Generally speaking a T98 trans is a 4spd which would require an eleven inch clutch and therefore a HD throw out bearing....
My book shows all trucks (all engines and trans') up to F-750's using the same throwout bearing
Old 08-03-2017, 01:32 PM   #7
hbiehl
So as a follow-up, is it possible to change the flywheel so that an 10 or 11 inch clutch will bolt up? What needs to be done to the motor to do this if possible?
Old 08-03-2017, 01:38 PM   #8
19Fordy
19Fordy's Avatar
Contact some of the folks in this thread.
https://www.fordbarn.com/forum/showt...+clutch&page=2
Old 08-03-2017, 06:31 PM   #9
Karl Wolf
Karl Wolf's Avatar
Some one will be happy to let you have an 11" flywheel for a lot less than the cost of drilling one.
My two fit 59AB, and are near 94941, SF, Ca. The shipping would be silly.
Karl
Karl Wolf is offline   Reply With Quote
Old 08-03-2017, 09:10 PM   #10
JSeery
JSeery's Avatar
Have you considered going with a different transmission and using the flywheel and so on you have? Unless you plan on pulling tree stumps there is no need for an 11 inch clutch setup, IMO. If it was me I would figure out a way to use the clutch setup I had (you can get a custom clutch to fit the splines on the input shaft) or look at different transmission options.
Old 08-04-2017, 01:35 AM   #11
Ray Balukas
Ray Balukas's Avatar
Ft Wayne clutch can help you. Will build you a PP with heavier springs if needed. Talk to Kerry. Re
gards Ray
Ray Balukas is offline   Reply With Quote
Old 08-04-2017, 05:25 AM   #12
Mac VP
Mac VP's Avatar
First of all, do you have the correct 1953 F-100 bell housing with the motor? You really must start with this. The motor mount setup for 1953 was unique to the F-100 as well as the clutch release parts.
Assuming that you have the 53 bell housing, you could use the flywheel drilled for a 10" long style clutch, but most of the trucks with the 4 speed transmission came with the 11" clutch. If you're planning on using this pickup truck for pleasure driving, the 10" would suffice.
As you've learned, the flywheel that is drilled for the 9-1/2" clutch will not work in the pickup truck. Also, all Ford trucks starting with 1953 models used a longer transmission input shaft (and corresponding deeper bell housing).
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 08-08-2017, 02:19 PM   #13
hbiehl
How do I figure out if I have the correct bell housing? I do know that all the bolt holes line up.
Old 08-08-2017, 02:39 PM   #14
flatheadmurre
flatheadmurre's Avatar
If you rear motormounts on the bellhousing fits your frame your good to go...
Old 08-08-2017, 02:56 PM   #15
JSeery
JSeery's Avatar
Which bellhousing has mounts to the frame on it, I haven't seen that one?
Old 08-08-2017, 03:28 PM   #16
hbiehl
Excellent! Yes it does mount to the frame.
Old 08-08-2017, 03:57 PM   #17
JSeery
JSeery's Avatar
Can someone post a photo of the bellhousing, this is something I'm not familiar with (among thousands of other things!).
Old 08-08-2017, 04:01 PM   #18
flatheadmurre
Here you go
Not sure if the boltpattern is correct -53 or it´s a later one
Old 08-08-2017, 04:06 PM   #19
JSeery
JSeery's Avatar
Yep, never seen one! Thanks flatheadmurre. Seems like a strange engineering approach to me, but obviously it worked.
Old 08-08-2017, 04:06 PM   #20
flatheadmurre
Second try with a correct boltpattern.
