11-27-2020, 06:39 PM | #1 |
Replacing grease wide 5 front drums
I cleaned up real nice set of wide five front drums. I had to scoop out what seemed like a 1/2 of a tube of grease out of each one. I cleaned up the bearings and plan pack them and reinstall them with a new seal.
My question is is the cavity between the bearings supposed to be full of grease? Thanks |
11-27-2020, 06:48 PM | #2 |
Re: Replacing grease wide 5 front drums
No, just grease the bearings. Filling the center cavity does nothing and is just a waste of grease.
Sent from my iPad using Tapatalk |
11-27-2020, 07:04 PM | #3 |
i use the center of the hub to wipe the excess grease off my fingers. edge of dust cap works good for that too
11-27-2020, 07:15 PM | #4 |
The grease hadn’t seen the light of day for a long time. It was very black and seemed different from modern wheel bearing grease
11-27-2020, 07:59 PM | #5 |
You know, it IS entirely possible that grease is approaching 85 years old. DD
11-27-2020, 08:05 PM | #6 |
11-27-2020, 09:21 PM | #7 |
11-28-2020, 10:01 AM | #8 |
Are these the Timken Grease Guidelines mentioned above?
https://www.nodeshk.com/timken/art/g...uidelines.html |
11-28-2020, 07:36 PM | #9 |
https://www.carid.com/images/timken/...structions.pdf Try this there about the easiest to follow ive found basic end game you need endfloat or you will damage the bearing
