Old 11-17-2020, 10:56 AM   #1
mgambuzza
mgambuzza's Avatar
Default Engine Bolt question
Hopefully easy question. Was wondering the function of the bolt circled on the passenger's side. I do have an oil seepage issue, and will likely result in replacing gaskets, but I was wondering about this as it also had a screw slot in it.
mgambuzza is offline   Reply With Quote
Old 11-17-2020, 11:03 AM   #2
jetmek
Default Re: Engine Bolt question
Looks as tho someone jammed a dist hold down screw in there. Wrong threads. It wants a 1/8 pipe plug. It serves no purpose other than to plug the hole
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 11-17-2020, 11:09 AM   #3
john charlton
john charlton's Avatar
Originally it was a brass slotted plug with a gas thread . To hold the oil pump in place when the oil pan is dropped some folks screw in a bolt to stop the oil pump falling out . A UNF thread bolt is not a gas thread and the thread in the block gets damaged hence some weeping can occur . A fix is to use the white plumbers tape wrapped around the bolt if you are careful.. the block thread is damaged anyway so no more harm can be done You might be lucky that the slotted plug with the nut could be the correct thread .
John in Suffolk County England .
john charlton is offline   Reply With Quote
Old 11-17-2020, 11:16 AM   #4
fundytides
fundytides's Avatar
Someone had butchered mine in the same way. I put a bolt in with a lock nut to hold the bolt in place without tightening it up against the oil pump. I then got an oil pan plug gasket and installed it between the nut and the block. No more leaks! You can then use the bolt when needed to hold the oil pump in place if you are removing the oil pan. Just loosen the lock nut and snug up the bolt enough to hold the pump. Do not over tighten, I don't know if it can happen but I would be afraid of doing damage to the pump housing.
fundytides is offline   Reply With Quote
Old 11-17-2020, 04:11 PM   #5
1931 flamingo
1931 flamingo's Avatar
It's also where one would put the line if using an oil pressure gauge.
Paul in CT
Old 11-17-2020, 05:29 PM   #6
Bruce of MN
Bruce of MN's Avatar
This is the tool to screw in there to keep the oil pump from falling out when you remove the pan. Easy to make your own!
Bruce of MN is online now   Reply With Quote
