Old 09-10-2020, 07:57 AM   #1
Sid
Sid's Avatar
Default Stromburg linkage ball
Has anybody had any experience using the Stromburg linkage bomb ends on the early 97's? Part number 9164-K and are sold by Stromburg and I see them at Summit also. Are the new Stromburg linkage balls slightly larger then the old 97's? If these ends wont work on the early Stromburg's then what end will. I want to make my own gas pedal rod and eliminate the annoying spring loaded rod that stretches when you step on the gas pedal.....Thanks
Sid is offline   Reply With Quote
Old 09-10-2020, 04:57 PM   #2
Ian NZ
Ian NZ's Avatar
Default Re: Stromburg linkage ball
I built my stromberg ball ends up with weld and carefully filed them until they were a 1/4inch round.
Ian NZ is offline   Reply With Quote
Old 09-10-2020, 06:32 PM   #3
Bob NH
Bob NH's Avatar
Hmmm, I did that too. Not a hard job
Bob NH is offline   Reply With Quote
Old 09-10-2020, 07:26 PM   #4
uncle max
uncle max's Avatar
These work perfectly for what you want to achieve.
Cut your own 3/16" rod to length and thread the ends 10-32 with a die. Eliminates the "mush" of the old rod and can also be used on the choke and/or hand throttle as well.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 09-12-2020, 07:51 PM   #5
Mike..Yorba Linda
I just did exactly what Max explained on my ‘56 F100 and it works great. A nicely made piece and looks good.....
Mike..Yorba Linda is offline   Reply With Quote
