Old 09-05-2020, 09:46 AM   #1
Yoyodyne
Yoyodyne's Avatar
Default Oversize OD main bearings for 37 21 stud block
The very last check I made before taking my oh so carefully cleaned tested and prepared 37 block to be bored was to bore gage the mains to be sure I had the correct main caps installed. In the process with the aid of searches here on the Barn I discovered that the main bores are .015" oversize. I understand why, but now I need bearings, or else I have to start the process over with yet another block, this is the 5th block I've cleaned and magnafluxed to get one useable block.
Does anyone here have those bearings for the .015 oversize bores? Or can you direct me to someone who might? My crank is .020 under, but I'd consider any undersize, doing another crank would be faster than finding another block.
I had one knowledgeable Barner tell me that Ford never made a rear main bearing for oversize blocks, is that true? My block has all 3 bores oversize.
I've been pondering how to sleeve the bores to make them work with standard bearings. We have ways, but it seems to be impractical. Anyone ever try it?
Yoyodyne is offline   Reply With Quote
Old 09-05-2020, 10:51 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Oversize OD main bearings for 37 21 stud block
I have some oversize in the block rear mains inserts --don't know exact sizes though, can look later today
Old 09-05-2020, 11:39 AM   #3
Bob C
Try Fred at Southside Obsolete. http://www.southsideobsolete.com/Sou...e/Welcome.html
Old 09-05-2020, 11:49 AM   #4
JSeery
JSeery's Avatar
Originally Posted by Yoyodyne View Post
... or else I have to start the process over with yet another block, this is the 5th block I've cleaned and magnafluxed to get one useable block.
Be sure to get the block pressure tested, mag doesn't find all of the possible cracks on a flathead block. Better to find a problem before you sink a lot of money into it.
Old 09-05-2020, 11:59 AM   #5
Yoyodyne
Yoyodyne's Avatar
Just finished that with this block. Disassemble, clean, mag, derust, pressure test, etc 5X. I keep finding new ways to find problems.
Where are those new blocks Tod?
Old 09-05-2020, 12:36 PM   #6
cadillac512
cadillac512's Avatar
McMaster -Carr has shim stock sheets in .007 and .008 thicknesses with a half thou tolerance spec. About 16 bucks a sheet. I'd be tempted to cut some shims and measure the bores with bearing inserts installed. The bearing crush will keep it in place,no problem.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 09-05-2020, 12:59 PM   #7
Yoyodyne
Yoyodyne's Avatar
Originally Posted by Bob C View Post
Is that Barnfind08?
Old 09-05-2020, 02:11 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
Is that Barnfind08?
That's him...Fred Wilmer! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 09-05-2020, 02:15 PM   #9
Phil Gillespie
Phil Gillespie's Avatar
Is that Barnfind08?
Yes it is .
Also there is Red at Reds Vintage Spares not to be confused with Reds Headers.
He also stocks some odd sizes. I have just got a plus 30 cam bearing off him.
Good Luck.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 09-05-2020, 02:20 PM   #10
Chuck Kuntz
I have some of those bearings. Need to check for .020
Chuck
Chuck Kuntz is offline   Reply With Quote
Old 09-05-2020, 02:20 PM   #11
Chuck Kuntz
Chuck
Old 09-05-2020, 02:27 PM   #12
Yoyodyne
Yoyodyne's Avatar
I asked him, he doesn't have them. That's who told me there were no rear mains made for this.
Old 09-05-2020, 02:27 PM   #13
Yoyodyne
Yoyodyne's Avatar
Chuck
Please! PM sent.
Old 09-05-2020, 03:48 PM   #14
Bob C
I saw that in the parts book. They show front and center but no rear.
I think it showed .010 and .030 with .015 OS for rear.
Old 09-05-2020, 04:47 PM   #15
Yoyodyne
Yoyodyne's Avatar
I see. He wasn't specific, just said Ford didn't make them. I asked for other sizes, got no answer so I took that as no rear bearings of any size made.
Old 09-05-2020, 06:09 PM   #16
Brian
Brian's Avatar
The rear main .015" os in block, .020 on journal is #68-6331 Z However, the length between flanges in block is .010 us. total length thrust to thrust is std. Check the width of your blocks flanges.
Old 09-05-2020, 07:18 PM   #17
Yoyodyne
Yoyodyne's Avatar
The block is 2.083" I have a rear cap from a junk block that measures 2.090" Is the 2.090 standard?
Old 09-05-2020, 07:56 PM   #18
Brian
Brian's Avatar
Standard length is 2.095-2.097
Old 09-05-2020, 07:59 PM   #19
Brian
Brian's Avatar
if you can't find .020 bearings, 68 6331 AA is .030 on crankshaft, .015 os and again .010 shorter @ flange
Old 09-05-2020, 08:18 PM   #20
Yoyodyne
Yoyodyne's Avatar
Thanks very much for that Brian. Looks like neither length is correct here. The length issues I can deal with, we have ways to machine it and I can even handscrape if necessary. Putting material on is tougher, but a spacer or shim on the length would not be fatal.
