Old 08-04-2020, 08:46 PM   #1
Tom's36coupe
Tom's36coupe's Avatar
Default Lost part, lock ring for speedo
Took the cable off seven years ago when starting my project and noticed today that I can't find the screw ring that holds the speedo cable to the drive shaft. Any idea on who might have a replacement part? So much for thinking of everything! lol.
Tom's36coupe is offline   Reply With Quote
Old 08-04-2020, 08:55 PM   #2
Zeke3
Zeke3's Avatar
Default Re: Lost part, lock ring for speedo
Holy cow, I didn't know you could get that piece off the cable assembly without destroying it. I will have to look at mine again.
Zeke3 is offline   Reply With Quote
Old 08-05-2020, 12:57 AM   #3
deuce lover
deuce lover's Avatar
Are you sure it hasn't slid back ? To put the replacement nut on that is gone ,one end that is crimped will have to be removed .Suggest you replace the cable & casing assy. Not expensive.
Old 08-05-2020, 09:38 AM   #4
38bill
38bill's Avatar
It shouldn't come off unless the cable end has been damaged. I'm betting that it has slid forward on the cable.
38bill is offline   Reply With Quote
Old 08-05-2020, 11:05 AM   #5
Tom's36coupe
Yep! call off the dogs...during the paint job process it got slid way ahead by the frame. All good, cleaned up and went right on. Sorry to bother my friends with this!
