07-14-2020, 04:00 PM | #1 |
Re-torque head nuts
I had to pull three studs due to leaking. I cleaned, resealed and installed them back in the block. The heads are still on the motor.
My question is how do I torque these down? Should I torque them in steps? 45,50,55? Should I torque all the head studs in sequence again? (I already did my five hot/cold cycles, five because of the supercharger and manufacturers recommendation). Do I simply re-torque these straight up to 55 lbs? The stud are #1, #10 and #13 Thank you, Joe Last edited by jrvariel48; 07-14-2020 at 05:03 PM. |
07-14-2020, 04:23 PM | #2 |
Re: Re-torque head nuts
I don't know if there is an official procedure.
Gut feeling tells me that I would torque directly to the previously torqued value. Straight to 55 lbs ft. But then make sure these get rechecked over three or more heat cycles. (check them all). I just keep checking them all until nothing moves any more. Mart. |
07-14-2020, 07:32 PM | #3 |
my thoughts follow the factory sequence cant go wrong if its tight it wont move and you've checked all the rest at the same time
07-15-2020, 12:57 PM | #4 |
Hi Joe, hope all's well?
You still battling the stud leaks? No need to retorque single studs in steps, just go straight to the necessary torque (55#) Thanks, Gary in N.Y. P.S Did you get the pan gasket (dipstick) OK. Went out of here a while back! I sent a little heavier one to you.
http://www.stromberg-bulletin.com/me...berg-equipped/ |
07-15-2020, 04:16 PM | #5 | |
07-17-2020, 07:21 PM | #6 |
07-17-2020, 07:38 PM | #7 |
I use teflon hi temp thread sealer from napa. Fuel and antifreeze resistant and works great
07-17-2020, 07:58 PM | #8 |
Joe for lord knows how many years all I ya used is 3m weatherstrip cement on a kazillion chevs & flatheads head studs or any stud/ bolt in water jackets with zero issues.
Cheers TP |
07-18-2020, 05:07 AM | #9 | |
Thanks |
07-18-2020, 05:07 AM | #10 |
07-18-2020, 06:03 AM | #11 |
Yellow or black in tube.
07-18-2020, 01:27 PM | #12 |
07-25-2020, 12:50 PM | #13 |
Well I tried the Permatex high temp with teflon and they still leak as bad as they did originally. I'm going to try Kiwi's idea with the 3M weatherstrip adhesive.
Am I missing something here?? The first time I used Permatex Aviation and just lightly snugged the studs in the block. The second time I hand tighten. Anyone want to chime In??? Third times a charm |
07-25-2020, 01:00 PM | #14 |
The trouble with thread sealers is that they are typically made to seal tapered threads (pipe threads). What is needed on a straight thread (like a stud going to water) is a sealer that "sets up" or "cures". I like to use a good brand of RTV silicone on the threads and lightly snug the studs into the block. The threads on studs and block must be scrupulously clean and bone dry when installing,and a few hours without water on the back sides to cure. They never leak,and come out easily next time.
Alternately, loctite blue (242) can be used as well. It will be a bit harder to remove next time but will seal well. Terry
07-25-2020, 04:11 PM | #15 |
Thank you Terry!
07-25-2020, 04:14 PM | #16 |
I have found this sealant to work EXCELLENTLY. Bought this at O'Reilly's.
07-25-2020, 04:14 PM | #17 |
I friend stopped over today and noticed the studs were still dripping after the car was turned off for about 10 minutes. I'm running an aftermarket radiator that came with a 16lb. cap. Could this be a pressure issue?? I ordered a 7lb. cap which was the lowest I could find.
07-25-2020, 05:06 PM | #18 |
07-25-2020, 10:17 PM | #19 | |
07-26-2020, 09:57 AM | #20 | |
I can run it all day with the electric fan on at a steady 190*. The temp hasn't gone past 190* even when it was 94*outside and I was driving it hard for an hour. I put the 7lb. cap on this morning before a ride. When I turned off the car, only three out of five were dripping. So I'm not really sure what's going on yet. Still running straight water at the moment until this is straightened out. I'm still going to pull the leaking studs, clean and reinstall with Permatex Thread sealant with PTFE Thanks |
