Old 07-01-2020, 04:28 PM   #1
jimTN
Default very early lugnuts on 28
What socket size are the lugnuts on a early 28. Mine are made like T lugnuts but slightly larger, between 11/16 and 3/4. I think it may be something in 64th or 32nds. Model T lugnuts are 21/32.
jimTN is offline   Reply With Quote
Old 07-01-2020, 04:57 PM   #2
jimTN
Default Re: very early lugnuts on 28
Resolved, 23/32nd or more commonly 18MM.
Old 07-03-2020, 08:55 PM   #3
Gene F
Gene F's Avatar
Interesting. I think I have some.
Gene F is offline   Reply With Quote
Old 07-21-2020, 09:01 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Let's bring this topic up again. Is there a difference between the T lug nut and the A lug nut on the early 1928's? I am showing a part number of A-21837 for the early style that eventually was changed to A-21837-AR when the A-21837-B Hub Bolt (Lug) Nut was introduced.
Seeing that it did have its' own A part number makes me believe it was different than the T hub bolt (lug) nut. Can anyone confirm and share the differences?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-21-2020, 08:44 PM   #5
JoeCB
JoeCB's Avatar
Just as an aside, 23/32" apparently was a standard size nut. I encounter this size on occasion and have a couple of open end wrenches in that size. It's not truly 18mm as 23/32" converts to 18.3mm but that mm size will surly work.
Joe B
JoeCB is offline   Reply With Quote
Old 07-21-2020, 09:57 PM   #6
Roadster62
Roadster62's Avatar
Just going from memory and I don't have either here, the early A lugs are shorter that the wire wheel T nuts. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 07-22-2020, 10:17 AM   #7
BRENT in 10-uh-C
Thanks guys. I have lug nuts that are very similar but slight variations. I think out of 70 something lug nuts that I have, there are about four different variations in what I have. I wish I could get to see a print on these.
BRENT in 10-uh-C
Old 07-24-2020, 10:24 AM   #8
ML28
The Release for A-21837-AR says "Use T-2809".
The Drawing T-2809 shows a 11/16" diameter, height 1-1/8".
ML28 is offline   Reply With Quote
Old 07-25-2020, 12:06 PM   #9
katy
katy's Avatar
11/16" diameter or AF?
