Old 05-28-2020, 09:09 PM   #1
bobscogin
Default '28-'29 Pickup cab to bed gap
If I could ask a favor. -- On a '28-29 pickup with original cab and bed locations, how wide is the gap between the back of the cab and bed, measured at the top of the bed panel? Thanks,
Bob
bobscogin is offline   Reply With Quote
Old 05-29-2020, 12:16 AM   #2
Dan Partain
Dan Partain's Avatar
Default Re: '28-'29 Pickup cab to bed gap
Bob,
I get a measurment of about 3/8" to 7/16" on the one I have that is straight. This is measured at the center of the bed panel to a flat spot on the rear center of the cab.
-DAN
Dan Partain is offline   Reply With Quote
Old 05-29-2020, 01:39 AM   #3
Jembow
Jembow's Avatar
My bed is off right now, but that sounds about right to me.
Jembow is offline   Reply With Quote
Old 05-29-2020, 08:20 AM   #4
Neil Wilson
Neil Wilson's Avatar
Originally Posted by bobscogin View Post
If I could ask a favor. -- On a '28-29 pickup with original cab and bed locations, how wide is the gap between the back of the cab and bed, measured at the top of the bed panel? Thanks,Bob
Bob, the important measurement you need is the spacing at the vertical join-strips for the rear/side cab panels and the pickup front panel. The cab and pickup bodies are located via the body bolts. Consequently, spacing is not adjustable.
Sorry, I only have an AA express (similar to the pickup body). My express has 1/8" spacing at one join-strip and 3/8" at the other join-strip. Original spacing would have been equal.
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
Old 05-29-2020, 12:05 PM   #5
Gary Karr
Gary Karr's Avatar
My early '29 is 3/4" between the bed and back body panel. Note that an early '28 OCPU with the integral subframe for body and bed will have a shorter distance between the two.
Gary Karr is offline   Reply With Quote
Old 05-29-2020, 08:51 PM   #6
bobscogin
Thanks to everyone for the input. I know a question about the cab/bed gap may seem odd, but I fabricated my A frame from scratch and am trying to get the bed location as accurate as possible relative to the cab. With acknowledgement that this section of the forum isn't for hot rods, a photo may better illustrate what I'm working with so here you go. Nostalgia style build powered by a '42 Mercury V8.
Old 05-29-2020, 11:58 PM   #7
Dan Partain
If you haven't seen this, it may be of some help for you.
http://www.wescottsauto.com/WebCatal...ram1928-31.pdf
