Old 02-29-2020, 06:33 AM   #1
johnbuckley
johnbuckley's Avatar
Default upper plate with integral clamp. provenance?
Not come across an upper plate like this before. Can anyone shed light on its origin?
Old 02-29-2020, 07:16 AM   #2
chrs1961815
chrs1961815's Avatar
Default Re: upper plate with integral clamp. provenance?
This is an early 28 plate. They are getting harder and harder to find. I only have three out of a lot of plates.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 02-29-2020, 10:25 AM   #3
Sunnybrook Farm
Sunnybrook Farm's Avatar
I have one of those that I ran for years, it was different and seemed to clamp the points better, probably my imagination. Now the real early 28s didn't have the points bolted in, they had a straight spring end and just slipped between pegs, it got changed because they were so easy to steal. Just squeeze them and they lifted right out.
Sunnybrook Farm is offline   Reply With Quote
Old 02-29-2020, 01:13 PM   #4
johnbuckley
Thank you, this ties in with the body of the dissy which is also early '28 I think.
Old 02-29-2020, 01:49 PM   #5
Gary Karr
Gary Karr's Avatar
What you have is actually the second generation of upper distributor plate which was introduced after January 1928 and used into late 1928 when it was replaced by the more familiar steel stamped plate. Of interest, the first generation upper distributor plate was also a forged plate with a wide arm but had a riveted ball. This was used from the beginning of production to January 1928.
Gary Karr is offline   Reply With Quote
