Old 08-29-2020, 02:14 PM   #1
rustythumb
Default leaky brake fittings
i've installed many brake lines back in the 70's & 80's using u.s.a. made parts with no problems. now i'm using off-shore tubes & fittings [all i can find] & getting lots of leaks! anyone else have this problem or is it just me?
rustythumb is offline   Reply With Quote
Old 08-29-2020, 03:21 PM   #2
TJ
TJ's Avatar
Default Re: leaky brake fittings
Are you using Dot5(silicone fluid)? If so it is prone to weep .
Old 08-29-2020, 05:56 PM   #3
FritzJr
FritzJr's Avatar
I try to use NOS or NORS parts as much as possible. I have had great difficulty with leaks with off-shore parts.
FritzJr is offline   Reply With Quote
Old 08-29-2020, 06:08 PM   #4
rustythumb
i use dot 3 only!
Old 08-29-2020, 06:45 PM   #5
RKS.PA
RKS.PA's Avatar
rusty, this might not be a solution for you, but I've gotten to the point where I make my own lines with a really good double flare tool, and have had good luck getting fittings locally that seem to mate well with the brake components. Also have a very good tubing bender and use the old line as a template and copy it as best I can.
Good luck on this project.
RKS.PA is offline   Reply With Quote
Old 08-29-2020, 07:12 PM   #6
JSeery
JSeery's Avatar
I make up my own lines and use older US made fittings and other parts.
Old 08-29-2020, 07:33 PM   #7
Brian
Brian's Avatar
I bought all my tubing and fittings from 'The Stopshop', dunno where they source it from, but I had zero problems.
Old 08-29-2020, 07:58 PM   #8
JSeery
JSeery's Avatar
I would also suggest you might get better parts from a dedicated brake/fitting supply vs a general auto supply. As a general rule it seems to me that a lot of auto parts suppliers are just looking for the cheapest parts with the greatest return money wise to them. While the suppliers dedicated to a specific product and who provide parts to professional shops might tend to carry a better line (as some of our Barn friends do to the early Ford market).
Old 08-29-2020, 10:38 PM   #9
fordor41
fordor41's Avatar
tighten, loosen a couple times to get a good seat on the fittings
fordor41 is offline   Reply With Quote
Old 08-30-2020, 08:25 AM   #10
john in illinois
john in illinois's Avatar
X2
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 09-01-2020, 08:12 AM   #11
32phil
One lesson I learned years ago.....
Always use a tubing cutter when cutting brake line. A hacksaw may be quicker but the line is prone to leak after double flaring.
Just sayin'.........
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 09-01-2020, 08:25 AM   #12
RKS.PA
RKS.PA's Avatar
Agree with Jerry on this one. Think the local "national" auto parts stores are pressed for profit margins, especially if publicly traded.
Hoping the "made in the USA" movement continues for materials and parts like this. And....even though I'm not the best craftsman on here, I get a certain amount of satisfaction in making stuff myself when I can.
Old 09-01-2020, 09:03 AM   #13
A bones
A bones's Avatar
Yes! Jerry knows.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
