Old 08-04-2020, 10:26 AM   #1
32phil
Default Tight windows
I just replaced the window channels in my 32 Tudor.
I installed a complete Bob Drake kit.
The door glass is a little tight especially the right side going up, down is OK.
The regulator works fine without the glass.
Is there a lubricant I can apply ?
A friend suggested bar soap or candle wax.
I kinda like the candle wax idea.
I remember my Dad having a tube of what looked like wax that he rubbed on the tracks in a Chevy he had. That was at least 60 years ago !
Any ideas ?
Thanks.
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 08-04-2020, 10:59 AM   #2
J Franklin
J Franklin's Avatar
Default Re: Tight windows
A little silicone spray might help without making a mess. I had to shave a window once to make it work easily. A glass shop can sand an edge and it shouldn't cost much. The shop I Used didn't even charge me.
Old 08-04-2020, 11:03 AM   #3
F1 MIKE
F1 MIKE's Avatar
Phil try motorcraft mini-vent window lube i used this stuff at ford for years .
F1 MIKE is offline   Reply With Quote
Old 08-04-2020, 12:30 PM   #4
Kube
Kube's Avatar
Phil, I have zero clue as to how the tracks are in a 32. I have had some issues with repop tracks for later years causing the same issue you've described.
Each time, the repop tracks were formed a bit too narrow. An easy, albeit frustrating fix.
Old 08-04-2020, 01:24 PM   #5
jetmek
Be cautious about using lube in the window channels. It mite dissolve the adhesive securing the felt to the rubber and then you'll have a real mess Happened to me
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
