Old 06-15-2020, 05:56 AM   #1
Charlville
Charlville's Avatar
Default Help Please 1929 Sport Coupe
Hi All
I'm re-trimming my 1929 Sport Coupe and I'm in need of some photos of the internal roof including how the how the opening rear window is suspended, plus the B pillar trims if someone would be so kind please?
Thanks
Kevin
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 06-15-2020, 10:36 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Help Please 1929 Sport Coupe
The back light flap has snaps on the bottom for attachment to the belt rail and to the center top bow. The snap parts are available for this. It just has to have studs installed on the top bow lower surface for it to be snapped in the up and open position.
Volume 5 of the how to restore your model A has a good run down on the Sport Coupe models. Bows and supports are wrapped with cloth and wrapped chip board pieces are used to cover the center top bow area. The kits from Classtique or Cartouche should come with all the soft materials for this. the card board pieces that go in the corners and up over the edge of the top have to be covered on the inside with fabric too. Those pieces, the edge wires, and the straps all help hold the top up and looking crisp.
The outer belt rail two piece snap molding is damn near unobtainium these days. Original landau bars are preferable but the cast aluminum ones will get the job done.
Old 06-16-2020, 10:19 AM   #3
TerryO
TerryO's Avatar
If you know anyone with a Nov./Dec. 1969 Restorer magazine there is a 20 or so page article on the '29 Sport Coupe with plenty of pictures.
TOB
TerryO is offline   Reply With Quote
Old 06-16-2020, 04:59 PM   #4
Charlville
Charlville's Avatar
Thank you 😊
Kevin Flood
West Berkshire UK
Old 06-16-2020, 05:00 PM   #5
Charlville
Charlville's Avatar
Thank you ��
Kevin Flood
West Berkshire UK
Old 06-17-2020, 06:23 AM   #6
Fairview
Kevin,
I can post detail photos for you if you still need them. My Model A is a 29 Sport Coupe done correctly.
Thanks, Jeff
Fairview is offline   Reply With Quote
