07-31-2020, 04:43 PM | #1 |
Radiator cap problem 31 coupe
I’m sure a simple answer. The radiator cap does not tighten down and hold. I can turn it until it catches but then when I push it further it slip loose again. Has to be an easy fix but let me know, Pete
[email protected] |
07-31-2020, 04:45 PM | #2 |
Re: Radiator cap problem 31 coupe
Maybe a thicker gasket.
07-31-2020, 06:51 PM | #3 |
Adjust the tabs/ears on the cap, x-2 on a new gasket
07-31-2020, 08:07 PM | #4 |
I used high temp red silicone sealer between the cap and the gasket and the problem was solved for me . Before that , when I would accelerate , water would escape around the radiator cap .
08-02-2020, 06:05 PM | #5 |
