Old 04-20-2012, 09:48 PM   #1
Randy
Randy's Avatar
Default Tarp Find '29 Coupe...update, now running...
I've been mostly into V8s, but found this coupe while jogging in my neighborhood a few years ago and was finally able to buy it just today. It's been under a tarp too long, the paint has deteriorated and the mice have taken their toll on the interior, but the engine # matches the title and there's essentially no rust-through anywhere, believed to be a 44,000 original mile car, although it has been repainted, a lighter green is visible under the spots where the darker green has peeled off. I'll get more pics this weekend.
Randy is offline   Reply With Quote
Old 04-20-2012, 09:55 PM   #2
quickchange
quickchange's Avatar
Default Re: tarp find '29 Coupe...
Wow some guys have all the luck, Great find , want to part with it, ??Look forward to more pictures ,
quickchange is offline   Reply With Quote
Old 04-20-2012, 10:05 PM   #3
Elcastor
Elcastor's Avatar
Some people have all the luck!!!
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 04-21-2012, 02:51 AM   #4
juke joint johnny
juke joint johnny's Avatar
Nice car What a lucky find !!! Get it running and Enjoy!!!!
John
juke joint johnny is offline   Reply With Quote
Old 04-21-2012, 04:46 AM   #5
Stinch
Stinch's Avatar
And to think I was in Austin 15 years ago and missed it. Great find and congratulations.
Rich
E30 68-B Cabriolet
Stinch is offline   Reply With Quote
Old 04-21-2012, 05:07 AM   #6
real550A
real550A's Avatar
Looks to be pretty complete, great find!
Mike B.
Model A's and Porsches since 1957
real550A is offline   Reply With Quote
Old 04-21-2012, 07:09 AM   #7
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Great looking car, it shows how damaging a tarp cover can be to the finish. Have fun sanding, looks solid though. You saved it just in time.
Barry B./ Ma. is offline   Reply With Quote
Old 04-21-2012, 10:01 AM   #8
bart78
bart78's Avatar
I would not bother sanding it. I would drive it like it is. It dont look to bad. Get what ever mechanical done to it and drive it.
bart78 is offline   Reply With Quote
Old 04-21-2012, 12:23 PM   #9
TK in LA
TK in LA's Avatar
Nice Patina!
TK in LA is offline   Reply With Quote
Old 04-21-2012, 03:25 PM   #10
milo
milo's Avatar
Good find....
You're born, you die, in between you build hot rods
milo is offline   Reply With Quote
Old 04-22-2012, 05:32 AM   #11
Greg Jones
Greg Jones's Avatar
Great looking car. Somehow I would try to keep the patina-look if it will clean up OK.
Greg Jones is offline   Reply With Quote
Old 04-22-2012, 07:42 AM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
Good looking car as is. I agree with clean and lube and drive it as is.
The fan belt looks like it's pulled too tight. It's also a bit worn and setting in the groove deeper than a new belt would be. I don't worry too much about some wear, as long as it isn't hard and cracking, or the outer layer starting to shread. Generators don't need to be very tight, just tight enough so the fan and generator don't slip.
Old 04-22-2012, 11:14 AM   #13
Vanspeed
Vanspeed's Avatar
I like that alot, keep her as is and just get her back on the road. Great find!
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 04-22-2012, 12:15 PM   #14
329s
Do you know where it was assembled?
See my website under Additional Studies...then go to Letters, Numbers and Codes and there you will find just how to ID the Assembly Plant.
www.plucks329s.org
Pluck
329s is offline   Reply With Quote
Old 04-22-2012, 01:25 PM   #15
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Looks like my Avatar car, "VERMIN!"
You should name it "VERMIN-2" Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-22-2012, 02:56 PM   #16
Randy
Randy's Avatar
www.plucks329s.org
Pluck
Wow, great website! Thanks for compiling that and for posting it here.
My body # is TC1348, so it was the 1,348th (1929?) body produced at the Twin City, MN, assembly plant. The gas tank is dated July 25, 1929, and the serial # corresponds to being stamped 5 days later on July 30, 1929. Very cool info!
Old 04-22-2012, 06:11 PM   #17
329s
Thanks Randy for that.
Actually, I think it was the 1,348 "coupe" body produced at TC plant.
And it is a "standard" coupe and not a "special coupe" for this time period as the special coupe was phased out about the end of July 1929.
This vehicle...if all original, was produced sometime in August 1929. It would be fun to take the MARC/MAFCA Restoration Guidelines and Judging Standards and compare the features within and to the car itself.
The use of "standard" coupe designation was introduced into the FORD volcabulary in 1930.
It appears???that someone converted it from a trunk to a rumble seat.
Pluck
Old 04-23-2012, 07:51 PM   #18
Randy
Randy's Avatar
Default Re: Tarp Find '29 Coupe...
Right, I guess the 1348th for the model year 1929?
That would be an interesting comparison. It was converted from trunk to rumbleseat. They never did even put the catch up top for the latch.
Thanks.
Old 04-23-2012, 08:02 PM   #19
Vanspeed
Vanspeed's Avatar
I know you are a v-8 guy and you have some beauties but that car is screaming for some 16's with firestones. Don't hate me everyone.
Old 04-23-2012, 08:46 PM   #20
Jordan
Jordan's Avatar
I want it.
Cowtown A's
Jordan is offline   Reply With Quote
