04-28-2021, 06:31 PM | #1 |
Flathead hot water heater control valve
I may have posted this before but if anyone knows of a supplier who properly duplicates the valve I'm sure it would be helpful for others to know. In the pic you will see one that I modified to be correct along with what they are selling. It still is not perfect as the original valve allowed you to bleed out any air that may have built up. The middle pic is the modified Macs valve.
04-28-2021, 06:46 PM | #2 |
Re: Flathead hot water heater control valve
No pics ?
04-28-2021, 08:36 PM | #3 | |
04-30-2021, 09:36 AM | #4 |
Sorry totally messed up will fix this later today
04-30-2021, 01:09 PM | #5 |
Veeder - is this for the '41 you usually ask questions about?
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 04-30-2021 at 03:21 PM. |
04-30-2021, 01:46 PM | #6 | |
04-30-2021, 02:28 PM | #7 |
Kube
I'm confused??? WHICH one is not correct.....the angle spout one you posted or the 90 degree spout petehoovie posted before your post??? My 39 Merc has one very close to IF NOT the same in your post!!!! The 45 Degree spout |
04-30-2021, 02:43 PM | #8 | |
Neither of the two that Pete had posted are correct.
04-30-2021, 09:44 PM | #9 |
When restoring my 40 deluxe wagon to be judged, I had a few valve bodies cad plated and started restoring them. Of course, then I found a NOS one at Hershey. That is now in my wagon. The best of my others I finished up and put in my business coupe. Both cars have hot water heaters. I know this is correct and I think the "Mickey Mouse" ears in the valve handle are suppose to be black. Mike will correct me if that isn't right but these are correct for 40 and probably other years that used hot water heaters. Notice the plane of the shutoff is 90 degrees to the part that screws into the head. |
