Old 03-16-2024, 02:32 PM   #1
SoCalCoupe
SoCalCoupe's Avatar
Default Spring removal and Columbia installation
Decided to start installation of my Columbia today and have the 1941 installation instructions. Haven't even gone to the garage yet because I'm stuck on the first sentence, "Disassemble Ford axle as shown in illustration No. 1."
How do I safely unbolt the spring from the shackles? From what I've read, the spring is under tension and if I remove one of the shackle bolts it will snap to the other side and maybe down. Should I use a spring spreader? Seems like I will need a spring spreader to reinstall it.
Help.
SoCalCoupe is offline   Reply With Quote
Old 03-16-2024, 02:36 PM   #2
deuce lover
deuce lover's Avatar
Default Re: Spring removal and Columbia installation
Yes spring spreader.Porta Power can be adapted also
Old 03-16-2024, 02:46 PM   #3
busmania
busmania's Avatar
In my 40, after overthinking and over worrying I just clamped it together with two large c clamps. Then remove bolt. Then slowly release c clamps. In my 40, there was probably only 2-3” of “spring” tension released upwards when it was all done.
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/
busmania is offline   Reply With Quote
Old 03-16-2024, 03:29 PM   #4
Kube
Kube's Avatar
I'm with you Deuce.
C-clamps? Yeah, they work until one lets go and a guy gets injured or worse.
Keep the spring installed to the frame. Remove it from the axle housing.
Old 03-17-2024, 12:34 AM   #5
SoCalCoupe
SoCalCoupe's Avatar
I'm a tool junkie. Would love to be the proud owner of a multi-purpose Porta-Power rather than a single use Ford spring spreader. I see this on Amazon. Seems like a couple of the tips there would work but obviously I don't want the whole thing to snap back in my face. Of course, the hose is long enough I wouldn't have to get too close.
Thoughts?
Old 03-17-2024, 12:52 AM   #6
ford38v8
ford38v8's Avatar
Necessity is the mother of invention. If you have a floor jack, a couple of jackstands, and the power of reason, the task becomes easy peasy.
Alan
Old 03-17-2024, 05:18 AM   #7
glennpm
glennpm's Avatar
I bought a Harbor Freight Porta-Power clone and made a second chisel end.
https://www.fordbarn.com/forum/showp...7&postcount=22
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat's Notes
Techno-Source for the 1932 thru 1953 Flathead Ford
Old 03-17-2024, 10:14 AM   #8
TJ
TJ's Avatar
If you have a tool rental store in your area you can probably rent one.
Old 03-17-2024, 10:19 AM   #9
glennpm
glennpm's Avatar
If you do rent, make sure that there are two wedge attachments.
Glenn
Rumble Seat's Notes
Old 03-24-2024, 02:34 PM   #10
SoCalCoupe
SoCalCoupe's Avatar
Borrowed a spring spreader and got started.
Took a last drive and topped off the tank with fresh gas.
Jacked up the driver's side of the car and removed the rear wheel and hub. Removed the four bolts from the backing plan and quit for the day when I realized I'll have to disconnect the brake line. Didn't want to get into that but there's no choice. Trying to figure out how to seal up the brake line and wheel cylinder when I disconnect them. Any thoughts?
Don't know what kind of brake fluid is in the car. Any thoughts on to identify it? What should I put back in?
Old 03-24-2024, 02:47 PM   #11
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Get the complete rear end off the ground, stands under the side frame rails. Put a Columbia under my 33 last month.
Tim Carlig
dean333 is offline   Reply With Quote
Old 03-24-2024, 02:57 PM   #12
petehoovie
petehoovie's Avatar
Old 03-24-2024, 03:15 PM   #13
Ken/Alabama
Ken/Alabama's Avatar
It’s easier to remove the whole rear axle with torque tube as a unit then replace it with the Columbia unit. To identify the brake fluid , put some water in a cup then put a little brake fluid in it . Dot 3 will cloud up the water. Dot 5 silicone will bead up into little bb’s
Old 03-24-2024, 07:57 PM   #14
SoCalCoupe
SoCalCoupe's Avatar
Sounds good. That's the plan. Felt more comfortable with one wheel on the ground first time pulling a hub. I like "belt and suspenders" with jack stands (two each side.) Being under the car supported by jack stands gives me the heebees. I have another pair somewhere but if I can't find them I'll go to Harbor Freight and buy a 2nd pair.
Sounds like a good idea but my garage is too small to remove the axle as a unit. Thanks for the tip on the brake fluid.
Old 03-24-2024, 08:10 PM   #15
dean333
dean333's Avatar
The 33/34 Columbia instructions say not to remove the torque tube. Oh contrare, we pulled the whole assembly with the tube and put it on a makeshift workbench to build the Columbia.
Tim Carlig
Old 03-24-2024, 08:46 PM   #16
Kube
Kube's Avatar
SoCal,
Unless I am restoring a car, I install the Columbia pretty much as outlined in their instructions. That is, I remove only the left axle housing.
Installing one of these units is rather easy.
Harbor Freight jack stands? Not certain what they offer but DO buy the best you can afford. None of those cheap metal units.
Old 03-24-2024, 09:56 PM   #17
SoCalCoupe
SoCalCoupe's Avatar
Originally Posted by Kube View Post
SoCal,
Kube, Thanks. I can afford the best jack stands; not sure what those might be, so much cr@p made in Ch!n@. Not a Harbor Freight fan at all. Just don't know where else to go for jack stands. Pretty simple product. But, willing to pay for the best to avoid having the car fall on my face.
Yes, Columbia conversion seems pretty easy all things considered. Really enthusiastic about this project.
Old 03-25-2024, 08:32 AM   #18
Kube
Kube's Avatar
Gosh, I'm not certain where to get high quality stands these days. Used to be WALKER brand were the best. They no longer exist.
NAPA sold Walker under their own brand name.
Craftsman used to sell good quality as well.
Old 03-25-2024, 09:04 AM   #19
glennpm
glennpm's Avatar
Nothing wrong with these. I have four sets of them and never had an issue.
https://www.harborfreight.com/3-ton-...nge-58346.html
Rumble Seat's Notes
Old 03-25-2024, 09:54 AM   #20
dean333
dean333's Avatar
Kube, I’m sure you meant removing the RIGHT axle housing.
I don’t know what you consider “easy”, especially if it’s up on jack stands. Adjusting the gear mesh pattern is an all day job….taking it apart at least three times to get the proper shim thickness. I can’t imagine doing that on your back as well as everything else. Everyone I’ve talked to says it’s an eight hour process.
Tim Carlig
