Old 04-10-2021, 02:53 PM   #1
Larryejoh
Larryejoh's Avatar
Default Gland rings counter bore
Does the block have a counter bore for the gland rings like the exhaust manifold do? My block doesn’t show any sign of any counter bore.
Larryejoh is offline   Reply With Quote
Old 04-10-2021, 03:57 PM   #2
Bob C
Default Re: Gland rings counter bore
See page 312 of the Service Bulletins. Looks like the counter bore ended in January 1929.
Old 04-10-2021, 04:40 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
I believe they only stopped using them for a short time then started using them again. My late 1930 block is machined for them.
From Bratton's catalog.
The 4 rings that seat into the manifold and block to prevent leaks. Ford discontinued using these for a brief time in early 1929. If the manifold or block has been resurfaced, the width of the gland rings will need to be reduced by the same amount.
Old 04-10-2021, 04:51 PM   #4
Larryejoh
Larryejoh's Avatar
Thanks. I think my block was made mid year in 29.
Old 04-10-2021, 10:15 PM   #5
Steve Plucker
This article might help you understand your block better:
http://plucks329s.org/pdf/enginebloc...ESCRIPTION.pdf
Pluck
Old 04-11-2021, 08:00 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
Hi Pluck. Your article about engines is a fantastic piece. Thanks for sharing it.
Bob Bidonde
Old 04-11-2021, 08:15 AM   #7
Larryejoh
Larryejoh's Avatar
Thanks for the article.
Old 04-11-2021, 09:03 AM   #8
JoeCB
JoeCB's Avatar
Steve, Thanks for posting that info... well done and very informative. From one that had a background in automotive engine manufacturing, each one of those seemingly small changes brought back (bad) memories, of piles of paper work "change orders", foundry pattern changes (many - many patterns) and hard tool and fixture changes on the machining line.
Joe B
JoeCB is offline   Reply With Quote
Old 04-12-2021, 01:43 PM   #9
d.j. moordigian
d.j. moordigian's Avatar
Odd,...my B/C blocks have them..
d.j. moordigian is offline   Reply With Quote
