06-17-2020, 08:01 PM | #1 |
Emergency brake anti rattle felt
Where does the anti rattle felt install on ‘30 emergency brake lever?
06-17-2020, 08:19 PM | #2 |
Re: Emergency brake anti rattle felt
The felt goes on the rod inside the emergency brake lever. It is intended to prevent the rod from rattling.
06-18-2020, 10:32 AM | #3 |
See the Ford Service Bulletin of April 1929, Page 337. There is a sketch of the brake lever showing the installation of the felt washer.
Bob Bidonde |
06-19-2020, 12:28 PM | #4 |
Thanks Bob I will look it up
06-21-2020, 06:00 AM | #5 |
Could you post a photo of that SB page.
06-21-2020, 11:09 AM | #6 |
Bob Bidonde Last edited by Bob Bidonde; 06-22-2020 at 11:25 AM. |
06-21-2020, 12:07 PM | #7 |
Screen shot of page 337
06-21-2020, 03:53 PM | #8 |
Thanks
I did not realize the lever button sleeve (A-2792) could come out of the lever tube. It sure doesn't look like it does. |
06-21-2020, 04:28 PM | #9 |
06-21-2020, 09:26 PM | #10 |
So the question remains. Without being able to remove the button sleeve, where does the felt washer go?
06-22-2020, 05:54 AM | #11 |
Well the button sleeve definitely is made integral with my ‘30 lever. When I disassembled there was a small hard fiber washer under the spring and the tiniest remnants of a felt washer. I think I did it wrong. I shoved the felt in from bottom side with a wire. I believe it has to go in from top somehow but hole seems too small?
