Old 05-04-2021, 08:14 PM   #1
MickyD
MickyD's Avatar
Default Tillotson carb
I had it rebuilt last year and it leaks internally. It did leak at the top seam but that has been fixed. It runs great except for the small leak. I checked the float and measured fine. I am confused about what to do next.
MickyD is offline   Reply With Quote
Old 05-04-2021, 09:16 PM   #2
700rpm
700rpm's Avatar
Default Re: Tillotson carb
Find a Zenith. There are lots of them and they aren’t expensive. Tilly’s are notorious for warping and leaking.
Ray Horton, Portland, OR
Old 05-05-2021, 11:08 AM   #3
Patrick L.
Patrick L.'s Avatar
Just where is it leaking ? Tilly's are good carburetors when in good shape. I think they run better than Zenith, but, not quite as nice as Marvel's.
The float can be set correctly, but, the needle may not be seating correctly/fully. There are several types of needle/seats, which do you have ?
Old 05-05-2021, 06:21 PM   #4
tnhammond
tnhammond's Avatar
Micky -
I agree with Patrick. Tillotson runs very well. I cannot argue that the Tillotson is better than Zenith because I have never had a reason to change or a Zenith to compare.
Our 1930 Coupe came to the family in 1957. It was equipped with a Tillotson and a spare Tillotson in a box of assorted parts. I completely rebuilt the engine in 1965.
Over the years, I have rebuilt each the two Tillotsons a couple of times.
The only times that I experienced leaks were when I did not get even pressure on the top screws and once when I had a bad float valve.
Tim
tnhammond is offline   Reply With Quote
Old 05-05-2021, 06:26 PM   #5
Herb Concord Ca
Tilly's are good carbs. Like Patrick said what type of float needle do you have. Buy a viton tipped float valve they work better with the corn gas we have to use today.
Herb Concord Ca is offline   Reply With Quote
Old 05-05-2021, 06:42 PM   #6
WHN
Get a Zenith and move on.
Years ago I tried to work with the Tillotson on a 31. It was just not worth the effort. Changed to a Zenith, never looked back.
Our 29 has never had a leaking carburetor in 41 years. Zenith. Easy to service. One less thing to worry about.
Enjoy
WHN is offline   Reply With Quote
Old 05-06-2021, 06:02 AM   #7
Patrick L.
Patrick L.'s Avatar
Almost like talking politics isn't it ?
Old 05-06-2021, 06:54 AM   #8
old31
Gee, let's talk about what oil Micky should use! That's worse than politics.
Just after the carb was rebuilt did it leak, or is this something that just started?
A tilly will out perform a Zenith any day. No reason to change. As noted above try a viton tip needle and see what happens.
When you say you checked the float, what did you check? Shake it and see if there is anything inside of it. Check the float level so that it is 5/8", you will need a gauge for that.
https://www.snydersantiqueauto.com/P...earchByKeyword
Old 05-06-2021, 06:54 AM   #9
Redbird
Redbird's Avatar
To fix the warping, I fixed mine by baking in the oven at 250 degrees with "C' clamps!
Redbird is offline   Reply With Quote
Old 05-06-2021, 07:29 AM   #10
nkaminar
nkaminar's Avatar
I recently bought a rebuilt Tillotson and it works well. No leaks or other problems. Like TN Hammond, back in the 60's boxes of spare stuff was easy to acquire and in a box came spare carburetors, including a Tillotson. I put it on my stock Model A coupe and thought that it performed better, including better idle and improved torque, but the opinion was subjective, not based on any testing data. I eventually went back to the Zenith for some forgotten reason. I now think that the Zenith and the Tillotson are fairly equivalent, given that they both are in good shape. But, again, this is subjective and not based on any data.
The major advantage of the Zenith is that it is cast iron not pot metal.
Old 05-06-2021, 11:46 AM   #11
Y-Blockhead
Y-Blockhead's Avatar
Old31, the float gauge you linked to is for a Zenith. Will it fit the Tillotson? Rennen's Corner has one for the Tillotson (and Marvel). https://rennerscorner.com/carburetor.html
After you get it flat, do not over-tighten the screws when reassembling. I only tighten the screws enough to flatten the lock washers, no more. As mentioned in another thread, I also cut my own gaskets out of .031" Cork/Buta-N. It is softer than the paper gaskets included in the kits and conforms better to seal. Use no sealant!
Old 05-06-2021, 04:30 PM   #12
old31
Yes, the zenith gauge will work but not as good as renners due to the shape of the tube. Go with Renners, he is a great guy to work with.
A-9599-TL
Description: TILLOTSON X XF CARBURETOR FUEL LEVEL SETTING GAUGE
Comments: High accuracy to set the float - fuel level / instructions included
Application: 1928 - 34
$16.00
Old 05-06-2021, 09:26 PM   #13
700rpm
700rpm's Avatar
Well, this is an advice and opinion site, so you have to expect advice and opinion.
Old 05-07-2021, 07:31 AM   #14
WHN
Great return!
Old 05-07-2021, 07:34 AM   #15
old31
OK, then I will give you some advice. And that my opinion!
Old 05-07-2021, 02:16 PM   #16
MickyD
MickyD's Avatar
I took the top off the carburetor and it looked to be 1" from the top. I am still looking to see exactly where the gas is coming from.
