Old 10-22-2023, 07:00 PM   #1
Sdmarsha1
Default Holley 94 problem
Hopefully someone here can help me out with my carb issue. I have a 1951 f1 with a stock flathead v8. I put a replacement carb from national carburetor 3 years ago, truck ran great. A couple months ago the power valve was leaking, so I replaced it with one that was rated too low, so it was flooding out. Just went through the carb and put a correct power valve and kit from vintage speed, now the carb has to have a little more than 1/4 choke or it dies. I have checked for air and vaccum leaks, carb runs 17in hg of vaccum at idle. I thoroughly cleaned the carb when I had it down, probably only had 100 miles on it when I tore it down. I have checked and replaced the vaccum advance. What recommendations does anyone have?
Sdmarsha1 is offline   Reply With Quote
Old 10-22-2023, 07:12 PM   #2
Phil Gillespie
Phil Gillespie's Avatar
Default Re: Holley 94 problem
Hows the air filter? Try running with this removed to check for restricted air flow?
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 10-22-2023, 07:23 PM   #3
Sdmarsha1
Filter seems fine. Doesn't seem to affect it any when I take it off.
Old 10-23-2023, 05:44 AM   #4
38 coupe
38 coupe's Avatar
Sounds like your idle circuits are not working. I would take the carburetor back appart and verify each passage is clear and all gaskets are accounted for. I use water as hot as I can stand and "flow" each passage at the shop sink (with screen over the drain in case I drop something) when rebuilding a carburetor. I sometime have to clean a passage with a single strand of copper from a multi-strand wire to clear a clog.
Old 10-23-2023, 06:19 AM   #5
Terry,OH
Terry,OH's Avatar
17 in of vacuum is low.
