Old 03-10-2020, 02:10 PM   #1
mercury39
Default Head Studs
how far out do the head studs stick out?
mercury39 is offline   Reply With Quote
Old 03-10-2020, 02:44 PM   #2
fuzes45
Default Re: Head Studs
In les book he gives dimension for stud height, will give correct amount so studs go through nut.
Bob
fuzes45 is offline   Reply With Quote
Old 03-10-2020, 04:55 PM   #3
Russ/40
Russ/40's Avatar
Dont have a measurement, but the studs (stock that is) have a crown on top. The crown and plus one thread i believe is correct.
Russ/40 is offline   Reply With Quote
Old 03-10-2020, 08:20 PM   #4
Doug Linden
Doug Linden's Avatar
The regular length studs should be 2 3/4" above the deck. The longer stud for the ignition switch (stud #8) is 2 29/32" and the long water outlet studs should be 5".
My HC head had been planed so I had to do a little adjusting to get the right fit.
Doug Linden is offline   Reply With Quote
