Old 10-23-2016, 01:02 PM   #1
Dave N.
Default Brake shoe material for cast brake drum
Is it soft woven material for steel brake drums and hard molded for cast brake drums?
What if you have the hard molded on steel drums?
Dave N. is offline   Reply With Quote
Old 10-23-2016, 01:29 PM   #2
James Rogers
James Rogers's Avatar
Default Re: Brake shoe material for cast brake drum
I prefer woven. The hard molded is more for hydraulic systems and the woven is better for mechanical brakes.
James Rogers is offline   Reply With Quote
Old 10-23-2016, 02:13 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Either will work on the cast iron drums, but I also prefer the woven.
Old 10-23-2016, 02:14 PM   #4
H. L. Chauvin
If you ever want to go on a very successful elk hunt for the first time, never a bad idea to call a hard core successful elk hunter who hunted and monitored elk every day for most of his life, just for his opinion.
You may or may not agree with all opinions.
But, if you call Mr. Randy Gross in CA, don't really know if he hunts elk, but he can offer his opinion after taking over his father's Model A Ford cast iron brake business.
Years ago, his father, Mr. Mel Gross recommended & provided bonded brakes on mine ......
they may recommend something different today, not sure ...... but like knee replacement for today's knees ..... (a) depends what type of material is used ...... and (b) depends who does the work.
Failure with (a) or (b) ........ and/or (a) + (b) occurs often; hence, different opinions.
H. L. Chauvin is offline   Reply With Quote
Old 10-23-2016, 08:43 PM   #5
Kevin in NJ
Really the key is proper set up.
Somehow I doubt anyone here is qualified to say which one is better as I doubt anyone has done a controlled set of tests to really know. I say this because there are really too many variables controlling brake function.
If you have spent enough time on this board you will find people saying good things about each and never really any negatives about either.
The correct answer is to spend the time and money to get shoes sized and centered to cast drums and you are most likely to have wonderful brakes.
Now to throw in some back ground on shoe types.
Ford started with woven then switched to a solid shoe. The change to solid shoes came before the cast drums. The solid shoe material is different then what you get today, but so is the woven stuff.
Doing A brakes is never cheap or easy.
Old 10-24-2016, 03:47 AM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I LUCKED OUT, Vermin came with beautiful, .010" oversize Steel Drums & woven linings, that have "maybe" 20 stops on them! The linings show full length contact, even!
BUT, don't wurry, I'm a downshift ARTIST, on downhills!
Bill Elated
"THE ASSISTANT GURU OF STUFF"
