Old 02-05-2024, 07:18 PM   #1
mcgarrett
Default Model A cam ground to "B" profile
What will this modification provide? What kind of power difference can I expect? The engine I'm putting it in has all new stainless valves, springs, new hard seats, new adjustable lifters. Anything I need to be aware of before installing it?
Old 02-05-2024, 07:36 PM   #2
Pete
Pete's Avatar
Default Re: Model A cam ground to "B" profile
You can expect mediocre performance from an antique cam grind.
There are lots of modern grinds that are easier on the valve train and give better performance.
Old 02-05-2024, 08:01 PM   #3
mcgarrett
Pete,
Thanks for your reply. I thought it might give a little bump in performance, but never had any firsthand experience myself.
Old 02-05-2024, 09:08 PM   #4
Keith True
Keith True's Avatar
I have two A engines with B cams in them.They both have Brumfield heads too.They go nicely.When I was doing some work on the pickup one year I loaned the engine to a friend while he was doing his engine over.He stuck his Stipe cam in my engine,what a difference.Makes you want to use the B cam for a tent peg after that.Of course he swapped them back when he finished his engine and returned mine,but it was a first hand education.
Old 02-05-2024, 10:14 PM   #5
mcgarrett
Keith,
I forgot to mention that I am also using a Brumfield head. I'm sure the combination of head and cam will be a noticeable improvement over my current stock setup!
Old 02-05-2024, 11:34 PM   #6
jeepguy1948
I’m told that the Burtz cam is a good grind. It can be used in a stock model A block with no modifications.
jeepguy1948 is offline   Reply With Quote
Old 02-06-2024, 08:10 AM   #7
nkaminar
nkaminar's Avatar
I am happy with my Burtz cam. A touring cam is a good choice too. Unless you are going racing and have lots of other modifications to your engine to support it, a racing cam is not a good idea.
Old 02-06-2024, 08:21 AM   #8
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Neil, do you (-or anyone for that matter) know what the specifications of a 'touring cam' truly are?
In my thoughts, Bill's IB330 cam is what comes to mind simply because it is a torque-style cam. I think most regrinds are just the opposite of what a 'tour' camshaft should be because they increase the lift at the expense of duration which means the engine must be operated at a higher RPM to obtain the same torque reading. We always hear we have a touring engine however I don't really know what the specifications are?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-06-2024, 09:07 AM   #9
Ruth
Can you even get a Stipe cam anymore? Or anything else. Their website doesn't even open?
Ruth
Old 02-06-2024, 10:21 AM   #10
BRENT in 10-uh-C
Your point is definitely valid. Bill & I talk from time to time and in one of our conversations he said he needed to redo some of his fixturing which has him on hold. I guess for the time being, a Burtz camshaft might be another good option.
BRENT in 10-uh-C
Old 02-06-2024, 10:40 AM   #11
mcgarrett
Appreciate all the comments and recommendations, but I'm going to run the B grind cam that came with the engine. No plans to spend more money since I'm on a budget.
Old 02-06-2024, 12:45 PM   #12
Jim Brierley
The Burtz cam is a copy of the Stipe 340. They are good but not cheap @ $400. Too hot of a grind in an otherwise stock engine can actually hurt performance. 'B' cams came in 3 different profiles, the most common one had .302" of lobe lift, next came one with the same duration but had .315" these were followed by one with a little more duration, about 5 degrees, and .339" lobe lift, these are somewhat rare, but make a nice touring cam.
Old 02-06-2024, 12:59 PM   #13
Ruth
Thanks for the info, Jim. Where does your cam(s) fit into all of that?
Ruth
Old 02-06-2024, 01:10 PM   #14
nkaminar
nkaminar's Avatar
Brent, All things about cams can be found here: https://www.tildentechnologies.com/index.html.
A touring cam is one that is designed to have more torque at the lower rpms. The lift will be greater and the duration set for the higher torque at the lower rpms. The picture below is what I mean. These are not Model A cams but the idea is the same.
I am not found of regrinds, for the reasons you gave, and because sometimes the quality is not there.
File Type: jpg Screen Shot 2024-02-06 at 1.14.45 PM.jpg (17.7 KB, 27 views)
Old 02-06-2024, 02:58 PM   #15
BRENT in 10-uh-C
Yeah, what I highlighted in red is the misconception.
About 15-20 years ago we had a discussion here regarding reground camshafts. The issue was when a Model-A/B cam was re-ground, the duration was changed which effectively moved the torque band UP the RPM range, -and not in lower RPM range. For awhile, I was modifying an aluminum timing gear to advance the cam by about 7° to counter this by trying to increase low-end. It might have helped a little but when Bill started his cam program, he changed the centerline and increased duration along with lift which made advancing reground cams obsolete. So again, most reground camshafts that are advertised as Touring cams really aren't IMHO.
And FWIW, I do think that guys like Bill, Jim, Pete, and maybe a couple others can regrind original camshafts with pretty decent quality. You just gotta have the right 'someone' to do it if a regrind is what you want.
BRENT in 10-uh-C
Old 02-06-2024, 07:43 PM   #16
Pete
Pete's Avatar
Touring cam. A cam with a personality that desires to be around other engines with touring cams.
RV cam. (Recreational vehicle) All cams in street driven antique vehicles are recreational.
3/4 cam. One that goes 3/4 of a mile before the engine blows.
Semi cam. One that is only half finished.
Stump puller cam. Obvious.
All terms generally associated with a cam regrind to mean more low rpm range torque (Off idle to 2500 rpm) and better fuel mileage.
To get slightly technical, this is accomplished by:
1 - Increasing lift velocity. (Most important)
2 - Slightly increasing lift.
3 - Decreasing duration.
4 - Decreasing overlap.
There are several other parameters involved also and all of them interact so cam design gets VERY complicated and is usually left to people with pointed hats that stir big iron cauldron's at midnight.
Old 02-06-2024, 08:22 PM   #17
johnneilson
Years ago working with VW and Porsche motors I took a VW cam and removed a single lobe
I then refinished and moly coated it
I put it on display as a 3/4 cam with a price tag of about $100
You would not believe how many not in the know tried to purchase it
Truth in advertising it had 3 of 4 lobes
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 02-06-2024, 08:25 PM   #18
Pete
Pete's Avatar
J
Giggle.
Old 02-07-2024, 12:04 PM   #19
Jim Brierley
I have many grinds to choose from. My 'C' grind is a copy of the latest B grind with a few thou taken off the nose (the pointy end) to attain longer lobe life. It makes a really good touring cam, smooth idle and power where you want it with an overdrive, etc. My next step up is a mild Winfield grind, a copy of his SU1R, designed for short-track racing. It has a little lope at idle but pulls really good up to about 3500 RPM. With this cam, stock size valves, mild smoothing of the ports, a single Stromberg 97 and one of my 7:1 heads, it produced 102 HP @ 3600 RPM.
The two fastest and easiest way to get power out of am A/B engine is to raise HP and install a bigger carb.
Old 02-07-2024, 01:11 PM   #20
jeepguy1948
I think that perhaps Jim you meant raise the CR (Compression Ratio) rather than HP
