02-09-2021, 01:04 PM | #1 |
Upholstery trims
So it appears the trim pieces are all installed prior to installing the panels onto the door? Are the tangs pushed thru then bent over or do they need a backing plate. I am a little confused on the installation
02-09-2021, 02:03 PM | #2 | |
Re: Upholstery trims
The escutcheon for the window crank does not have a backing plate, you install the door panel, then push the escutcheon over the window crank shaft and install it behind the window crank. The tabs on that one are short and just dig into the fabric. Don't forget the spring between the door panel and the door at the window crank. Check the parts supplier catalogues, they will give you some guidance. JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
02-09-2021, 04:27 PM | #3 |
Ok, I have a 29 coupe, now I have an idea of what I need to buy, have never seen springs behind door panels, but I see them in the catalogs. Guess I best make sure all my holes are correctly punched. Thanks
02-09-2021, 10:53 PM | #4 | |
02-10-2021, 08:41 AM | #5 |
Position the escutcheon where it is supposed to be; then mark where the 2-4 tabs are on the upholstery panel; then with an exacto knife cut small slits where the marks are; then push the escutcheon into the fabric and cardboard panel; turn the panel over and push down on the escutcheon to get a good fit; fit the metal "Oval" shaped backing plate over the tabs and bend the tabs over the backing plate. This is done before the panel is put on the door.
Pluck |
02-10-2021, 11:07 AM | #6 | |
Vern, if I'm correct, I would just make sure that the escutcheon for the window crank is centered over the shaft where you want it, then put everything together. Over time the pressure from the spring behind the door panel will push the door panel into the escutcheon and the tabs will penetrate the fabric and door panel by themselves. And no spring behind the door latch handle escutcheon, only behind the window crank. (Small end of the spring goes against the door, large end goes against the door panel). Sorry I don't have pics for you, I put my door panels on a couple of weeks ago and didn't get pics of the backs of them. JayJay
02-10-2021, 11:09 AM | #7 | |
Pluck |
02-10-2021, 02:16 PM | #8 |
Ok mr. Pluck, thanks for the input on the door handle escutcheon. I have one original which has resided in my small parts box for almost (I cannot believe that long) fifty years. I could see fabric remnants between the two pieces but no cardboard. Hence the confusion although it did not seem to make sense not to penetrate the board. As regards the window crank, I would have put the spring the other way as it seems to fit the escutcheon so nicely even though it is large for the hole in the board. The next challenge is the clips, any tips as to installing them. The previous panels used a type of ring shank nail with a keeper installed thru pre punched holes. I am using the clip on style, I need to transfer hole locations from the door to the board, then apparently notch the fabric at the clip locations. One must need grow an extra set of hands or something.f
02-10-2021, 03:04 PM | #9 | |
JayJay
01-13-2023, 02:49 PM | #10 |
Hi guys. These posts are helpful, but I have a problem that I hope that you can help me with. I bought my interior kit through Mac's for my 1930 Town Sedan and installed the escutcheons for the door latches on the panels. Of course the installation instructions did not include directions on how to install the latch escutcheons but I had the old panels to use as a guide. Now I am installing the panels and because the latch has to be located in the lower end of the escutcheon, the top of my panels are 1/4 to 1/2 inch above the top of the door, which is going to be a problem when I install the window trim. It seemed logical that the escutcheon would be centered in the pre-punched hole but that apparently is not the case. Any thoughts? Thanks.
01-13-2023, 09:10 PM | #11 | |
JayJay
01-14-2023, 12:32 PM | #12 |
Thanks JayJay. I will try that and so happy that I kept the old panels to refer back to.
03-23-2023, 04:42 PM | #13 |
Hi everyone. I hope that someone can help me with this question. I am installing the upholstered panel on the front passenger side door on my 1930 Town Sedan deluxe. The instructions say to nail the windlace on the hinge side of the door so that it is a little loose. Should the windlace wrap around the door panel so that when the door is closed that I can see the windlace? Also, the panel seems to be slightly wider than the door so that the hinge side is against the dash rail and when I adjust it towards the latch side, it rubs against the rubber bumper, but it still latches okay. It still appears to be a little tight on the hinge side. Should I split the difference?
Thanks for your assistance. David |
