09-27-2020, 03:56 PM | #1 |
Posies Front Spring install 1937
Installing a Posies front spring in my 37 ford. I have the assembled axle w / spring raised up into the front crossmember, but I think I might be missing something. It appears that I only have 2 flat bars to bolt to the 2 front crossmember ubolts. These will not tighten down on the spring as it appears the posies Spring assembly is not as thick as the Original. Old cotter pin holes not even close to the nut.
Thanks Mike |
09-27-2020, 04:04 PM | #2 |
Re: Posies Front Spring install 1937
I think most Posie springs are a thinner material than early Ford springs and require a spacer? On all the customer chassis I build I provide a 3/8th spacer withe spring clamp.
09-27-2020, 04:18 PM | #3 |
