Old 10-21-2021, 03:18 PM   #1
Ramblin Reck
Ramblin Reck's Avatar
Default Seat Belts to be installed on a 1939 Convertible
No instructions came with them. Think i know what to do but looking for any advice I can get. Thanks Just for front two seats.
Rumble seat passenger will just get ejected. May offer a parachute.
Ramblin Reck is offline   Reply With Quote
Old 10-21-2021, 03:42 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Seat Belts to be installed on a 1939 Convertible
Bolt to floor with reinforcements. DO NOT EVER bolt to CHASSIS! ! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-21-2021, 03:54 PM   #3
19Fordy
19Fordy's Avatar
If they are lap belts, install them so that the buckle is on the "inside strap" so that it doesn't keep falling out the car door. Also, Install them so that seat belts will accomodate folks of various statures when the seat is moved both all the way forward and all the way back. tack welded the nut to the large flat washer and used double sided tape to hold it in place as I didn't have a helper.
Old 10-22-2021, 12:41 AM   #4
Duke
I like the style of floor anchors that Julianos sells vs the flat washer.
Duke is offline   Reply With Quote
Old 10-22-2021, 01:02 AM   #5
petehoovie
petehoovie's Avatar
Originally Posted by 19Fordy View Post
If they are lap belts, install them so that the buckle is on the "inside strap" so that it doesn't keep falling out the car door. Also, Install them with the seat moved all the way back so you can move your seat forward for folks of larger stature. i tack welded the nut to the large flat washer and used double sided tape to hold it in place as I didn't have a helper.
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 10-22-2021, 07:44 AM   #6
Ramblin Reck
All good info for this Newbie. Thanks to all y'all! Should I use any kind of a sealant, like RTV, or Rust preventative? I know it is not a boat which is what I am used to drilling holes into, but this car is such a joy to drive, I want it to last another 82 years!
Old 10-22-2021, 08:10 AM   #7
19Fordy
19Fordy's Avatar
No sealant needed as water will not leak or seep in from under the floor board but, I would attach hardware to a painted surface. Here's a few more photos. My belts are 3 in wide.
Be sure NOT TO DRILL any holes in your mufflers or frame rails. Make sure your belts are installed so that they will "fit" both large and smaller folks when the seat has to be adjusted.
Old 10-22-2021, 02:04 PM   #8
petehoovie
petehoovie's Avatar
Old 10-22-2021, 05:08 PM   #9
19Fordy
19Fordy's Avatar
"Bigger is better." Thanks.
Old 10-22-2021, 06:48 PM   #10
Krylon32
I got everything to install belts in my 40 standard with a split bench seat moved back 3 inches from Julianos. I used the 72 in belts and they were non to long.
Krylon32 is offline   Reply With Quote
Old 10-25-2021, 01:14 AM   #11
fortyonerag
fortyonerag's Avatar
I have installed mine in my 41 convert in the same manner as 19Fordy.
I don't mean to hijack the thread, but has anyone got a way to stop the 'short end' falling behind the seat when you sit down?
fortyonerag is offline   Reply With Quote
Old 10-25-2021, 06:39 AM   #12
19Fordy
19Fordy's Avatar
Would a piece of velcro work?
Old 10-25-2021, 01:34 PM   #13
my4dv8
Use at least a 2”x2” doubler plate on the floor top and bottom with a tack welded nut on the bottom and 2 rivets to hold the deal in place.
my4dv8 is offline   Reply With Quote
