Old 10-21-2021, 01:44 PM   #1
jimvette59
jimvette59's Avatar
Default Shock arms
Please help identify these Shock Arms.
jimvette59 is offline   Reply With Quote
Old 10-21-2021, 02:13 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Shock arms
I don't have your answers, but this MIGHT get ya close! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-21-2021, 03:13 PM   #3
deuce lover
deuce lover's Avatar
Any part numbers embossed on them? Could be Model A's
deuce lover is offline   Reply With Quote
Old 10-21-2021, 05:40 PM   #4
jimvette59
jimvette59's Avatar
I think the shorter one is model A but the long one i don't know. It is about eight inches long and has no numbers on it only has a diamond shape with a S in it.
Old 10-21-2021, 06:08 PM   #5
jimvette59
jimvette59's Avatar
Originally Posted by deuce lover View Post
any part numbers embossed on them? Could be model a's
no.
Old 10-21-2021, 07:02 PM   #6
DavidG
DavidG's Avatar
Both are Model A, one front, one rear.
Old 10-22-2021, 09:35 AM   #7
jimvette59
jimvette59's Avatar
The longer one is to long for a Model A rear arm. Maybe a 33 or34
Old 10-22-2021, 09:54 AM   #8
deuce lover
33-34's have a tight 90 degree bend at ball end with the ball as part of the forging.
Old 10-22-2021, 10:25 AM   #9
DavidG
DavidG's Avatar
Original Model A arms have a flange next to the ball on the end which is absent starting with the '32 arms.
Old 10-24-2021, 02:29 PM   #10
jimvette59
jimvette59's Avatar
V8COOPMAN It looks like the Model A is very early before they figured out the arm would hit the body and as near as I can see in the ID chart you sent it could be a 36 arm. JMO
Old 10-24-2021, 02:48 PM   #11
DavidG
DavidG's Avatar
With respect, Model A shocks were mounted on the outside of the frame so there was no danger of a rear straight arm hitting the frame as the arms are attached with the ball ends facing outward, not inward. '36 arms had no integral ball ends and no Ford shock arm had a flange behind the ball end after 1931 As.
Old 10-24-2021, 02:59 PM   #12
jimvette59
jimvette59's Avatar
DavidG The Model A front arm is very early before the bent ones. I mentioned it would hit the body of the shock it's self. I don't know about the longer one as yet. Thank you for your intrest. Jim T.
