Old 10-19-2021, 10:33 PM   #1
dono50
dono50's Avatar
Send a message via MSN to dono50
Arrow Firewall accelerator assembly
On a 46 Ford flathead what is the easiest way to install the accelerator assembly that mounts on the firewall ? It is under tension.
dono50 is offline   Reply With Quote
Old 10-19-2021, 11:18 PM   #2
cas3
Default Re: Firewall accelerator assembly
We have to assume you are working on a 50 ford?
Old 10-20-2021, 12:34 AM   #3
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by dono50 View Post
What is the easiest way to install accelerator assembly on firewall to deal with spring ?
Is THIS what you are talking about? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-20-2021, 12:50 AM   #4
V8COOPMAN
V8COOPMAN's Avatar
Do these help visualize spring application? DD
T5 W/TORQUE TUBE
Old 10-20-2021, 02:24 AM   #5
dono50
dono50's Avatar
Sorry forgot to mention, it’s a 46 Ford
Old 10-20-2021, 02:34 AM   #6
dono50
dono50's Avatar
DD, it’s on a 46 Ford. The photo with the blue firewall looks like the setup I have.
Old 10-20-2021, 06:01 AM   #7
V8COOPMAN
V8COOPMAN's Avatar
Actually, both pics show the same type spring from two different angles. Sometimes, you just have to fight that spring with pliers to make it conform. DD
T5 W/TORQUE TUBE
Old 10-20-2021, 08:06 AM   #8
dono50
dono50's Avatar
DD, appreciate your knowledge and willingness to help.
