Old 06-07-2010, 03:41 PM   #1
Dave D
Default KR Wilson Tools
Do any of you guys have, or do you know of, either of these KRW tools for servicing the old Fords?
Dave D is offline   Reply With Quote
Old 06-07-2010, 05:07 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: KR Wilson Tools
I had one up untill a couple of years ago. A friend of mine in Columbus Ga now owns it.
Ken/Alabama is offline   Reply With Quote
Old 06-07-2010, 06:16 PM   #3
Dennis/Arkansas
Dennis/Arkansas's Avatar
Ken/Alabama, What are the tools pictured? Good to know in case I run across them in my wanderings. Dennis/Arkansas
Dennis/Arkansas is offline   Reply With Quote
Old 06-07-2010, 07:43 PM   #4
Ken/Alabama
The KRW 9350-A is a carb and fuel pump tester. It sits on the counter and the resevoir is filled with kerosene. It has an electric motor that runs the fuel pump just like when its on the car.The gauges tell how much fuel press and pump vacuum you have and you can connect the fuel pump to the carb and check for leaks ,set the float level and make other adjustments. The other tool is a bench mounted holding fixture for rebuilding fuel pumps.
Old 06-07-2010, 08:24 PM   #5
Dennis/Arkansas
Thank you very much Ken, I appreciate it! That is a very nice set-up. I'll be watching for them. Dennis/Arkansas
Old 06-08-2010, 12:21 AM   #6
Dave D
Hey Ken,
Do you think he would let me come by and take photos of it? Could you put me in touch with him?
Thanks,
Dave
Old 06-08-2010, 03:16 PM   #7
Bruce Lancaster
All I have ever seen is the pics in the Service Bulletin instructions for use. A big advantage is that you can set desired actual fuel level measured by the KRW sight glass using actual pressure developed by your own pump.
I have the sight glasses for both Stromberg and Ford carbs, but have never encountered anything but pictures of the machines.
Bruce Lancaster is offline   Reply With Quote
Old 12-19-2012, 03:45 PM   #8
BigDTexasKid
I own one of the Bench type Carb Rebuilding Fixtures. It was NOS when I
Found it. Dereald
BigDTexasKid is offline   Reply With Quote
Old 12-19-2012, 07:08 PM   #9
Harylufa
Harylufa's Avatar
Hi All!
Upload pics, I have been looking for this Bench
Thanks
Hary
I love my Ford V8 1946!
Harylufa!
Harylufa is offline   Reply With Quote
Old 12-19-2012, 07:50 PM   #10
DICK SPADARO
There was one of these at the v8 parts auction in echo, minnesota this fall. Interesting contraption checked carb flow and fuel pump operation. The one at the auction need the majority of the lines replaced as dry rot had kicked in i think the final price was under $800
dickspadaro.com
DICK SPADARO is offline   Reply With Quote
Old 12-20-2012, 09:04 AM   #11
Kurt in NJ
Kurt in NJ's Avatar
I don't have the machine, have only seen one at Hershey, but I do have this picture from a Ford engine reconditioning book showing a production use ---and of a larger bench fixture ----sorry about the bad quality, it is a picture of a photocopy of the book.
Old 08-28-2018, 02:07 PM   #12
cojones
cojones's Avatar
Found it. Dereald
would you consider selling the bench type carb rebuilding fixture? Mark
cojones is offline   Reply With Quote
Old 08-28-2018, 02:49 PM   #13
skidmarks
skidmarks's Avatar
Seen one at hershey once, and it was already sold.
skidmarks is offline   Reply With Quote
Old 08-28-2018, 03:12 PM   #14
RobR'35
RobR'35's Avatar
KR Wilson had a suppliment to their 1940 tools catalog titled.
(New Tools and Equipment for Cleaning-Testing FORD carburators,fuel pumps and engines )
In it I'd seen this tool and many others for servicing the 97 and 94 carbs, u don't see theses tools in the regular catalog.
RobR'35 is offline   Reply With Quote
