08-18-2021, 12:17 PM | #1 |
Water in intake ports
I pulled the intake off I noticed there was water in both intake ports. So I assume I may have a blown head gasket. I milled the head & put a new head gasket on, & I still have water in the intake ports. Anyone know what my problem is
08-18-2021, 02:15 PM | #2 |
Re: Water in intake ports
It could be a cracked block in the inlet tract . Take the manifolds off and watch what happens drips from the ports etc etc Make sure the rad is full it might only be a hairline crack in both ports and maybe solved with Barrs stopleak if you are very very lucky . If it drips from an exhaust port you have a big problem .
John in Suffolk County England . |
08-18-2021, 02:37 PM | #3 |
My guess is a valve seat has a crack. Pressure testing will find it quickly.
08-18-2021, 03:33 PM | #4 |
Far be it from me to even suggest but are you running it for a long time? A short run can produce condensation....I'm sorry if I insulted your knowledge base but I see you are new based on posts....
08-18-2021, 05:49 PM | #5 |
How do I pressure check it
08-18-2021, 06:14 PM | #6 |
08-18-2021, 08:36 PM | #7 |
I've just had this but front passage only and I was about 3,000 miles from home. I drained the coolant and replaced it with plain water, then added half a bottle of Chemiweld. I don't think you guys have that product but there will be something similar. By the time I got home, I had done another 4,000 miles and the motor is running fine.
