Old 07-11-2021, 12:06 PM   #1
Randy Lausch
Default Setting carberator float
Does anybody know how to set the floats on a Tellison and a marvel all state carb and do they bend them or do they add washers to the float valve and the measurements of the floats.
Randy Lausch is offline   Reply With Quote
Old 07-11-2021, 04:48 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Setting carberator float
On a Tilly one gasket tighten down,place the float hinge over the mounting bracket and install hinge pin-Turn he body upside down and if necessary, adjust he float by bending the float lever until it is parallel to the machined edge of the upper body to give it a distance of one inch from the bottom of the float top(top while inverted) to the edge of the upper body.
www.whidbeymodelaclub.com
Old 07-12-2021, 09:56 AM   #3
Y-Blockhead
Y-Blockhead's Avatar
Renner's Corner has float level adjustment gaskets for both the Tillotson and Marvel Carburetors. The also have float level gauges.
https://rennerscorner.com/carburetor.html
Old 07-12-2021, 12:03 PM   #4
Patrick L.
Patrick L.'s Avatar
I agree with bending the float arm. Bend it carefully with needlenose close to the hinge keeping the needle section smooth, clean and straight.
Old 07-12-2021, 05:44 PM   #5
burner31
burner31's Avatar
And make double sure the float is level with the carb
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
