Old 03-24-2020, 08:27 PM   #1
cojones
cojones's Avatar
Default Do 33-34 pickup trucks have rear view mirrors?
Does not seem to have original holes for a mirror?
cojones is offline   Reply With Quote
Old 03-24-2020, 09:59 PM   #2
Tinker
Tinker's Avatar
Default Re: Do 33-34 pickup trucks have rear view mirrors?
Best to my knowledge is no. My 38 truck did not either. Seen many adapt one. .... edited here, At best it had a drivers side mirror. (thanks david)
Mack Hils: ford pickups 1932-1952 is a decent reference. It can be found cheaper.
https://www.amazon.com/Ford-pickups-.../dp/B0006EDNO0
Old 03-24-2020, 10:02 PM   #3
DavidG
DavidG's Avatar
They all had an outside mirror attached to the upper door hinge, same as the '32s. There was no inside mirror, just like the station wagons.
Old 03-25-2020, 02:14 PM   #4
34FordFabricator
I believe this was the hinge pin mirror used on the pickup truck.
Bill
34FordFabricator is offline   Reply With Quote
Old 03-25-2020, 02:44 PM   #5
GaryU.
GaryU.'s Avatar
Either picture is reversed or mirror is on opposite side as posted. Otherwise that looks to be it, I think ?
GaryU. is offline   Reply With Quote
Old 03-25-2020, 02:44 PM   #6
35fordtn
35fordtn's Avatar
Bill
That is the bracket used starting in 1935. The 32-34’s used a short straight stem mirror. They are quite hard to find these days
35fordtn is offline   Reply With Quote
Old 03-25-2020, 02:54 PM   #7
cojones
cojones's Avatar
thank you Dave
Old 03-25-2020, 03:56 PM   #8
Scott/Mn
Scott/Mn's Avatar
Here are some photos of the outside rear view mirror that was on my '34 Pickup. I am currently using a chromed reproduction painted black.
Scott/Mn is offline   Reply With Quote
Old 03-25-2020, 04:48 PM   #9
DavidG
DavidG's Avatar
Scott,
That's the one.
Old 03-25-2020, 06:00 PM   #10
al's28/33
al's28/33's Avatar
On the angled lip above the windshield there are a string of pre-drilled holes that I mounted a rear-view mirror from my '28 Model "A" open phaeton. It has just the right amount of angle and length from the bracket to fit the same eye vision for seeing straight out the back window. I will try to post a picture.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 03-25-2020, 06:01 PM   #11
al's28/33
al's28/33's Avatar
Old 03-25-2020, 06:04 PM   #12
al's28/33
al's28/33's Avatar
Perhaps a previous owner drilled the holes but I have mounted my mirror and air-conditioner from the header brace. It's a mirror used on the "open" Model "A"s and I can see just fine outside the rear window. The black mounting bracket comes curved to fit the windshield frame but I straightened it out in my vice.
Last edited by al's28/33; 03-25-2020 at 06:07 PM. Reason: wanted to add more to same post
