02-18-2017, 04:34 AM | #21 | |
Re: Intro & Questions - '29 Special Coup
Welcome!! Seems like you have a handle on things. Did the Generator spin with engine running? There should have been a melt down if the Gen was working and the pulley spun as the battery is the real regulator when using a generator. Have you decided on 12 OR 6 volts? And this thread may help with carb adjustments, Carb adjustments Do you have any books yet?
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 02-18-2017 at 04:39 AM. |
02-18-2017, 09:58 AM | #22 |
Good luck on your Special coupe, as you can see in my avitar I have one that I restored in 1980 . Mine has the trunk and most Special coupes came that way, I find it very handy compared to the rumble seat when you want to carry things. I have a good idea that solved the problem of the missing belt rail trim if you want to PM me. The brass trim piece bought from universal Tire duplicates the original moulding in looks. You have a good looking project there, good luck. Barry
02-18-2017, 10:30 AM | #23 |
Welcome to the hobby. it looks like you are taking a real interest in the car. I hope you have looked into a local chapter, they usually have folks that share your interest and have lots of recommendations on where to find stuff etc. Bert's in Denver CO area is a good parts source for original parts and Arizona Model A in Chandler AZ also has lots of original parts both also sell reproductions so you can get both from them. Snyder's you were refereed to and Bratton's is another excellent choice. Hope to see you at a Model A event soon, there is a lot of fun to have in the hobby so get involved and go on a tour!
02-18-2017, 10:49 AM | #24 |
Looks great,needs a little bit,many of started with a lot worse.
02-18-2017, 08:40 PM | #25 |
Well, it *was* a lot worse. My dad sent me some pictures from back when she first arrived. This was back in 1978, I hadn't realized how long he has had this car!
02-19-2017, 08:25 AM | #26 |
02-19-2017, 04:48 PM | #27 | |
When grounding it out, does the wire run from the terminal on the cutout, or does the cutout need to be removed? If I take a chance on it and hook the cutout to the starter switch, is there a chance that if it is fried, it will cause a short, or other issues beyond just not charging? Assuming it is fried, how big a job is it to repair/rebuild? |
02-20-2017, 11:39 PM | #28 |
Got some time to fiddle around with the car today.
First up was to drain the coolant - not sure what it was, but it was a bit milky and there might have been some oil in there. I'm hoping it is just something left over from whatever work was done on it years ago, though the #3 & 4 plugs are rusty on the threads and tips. No sign of water on the dipstick. I'm hoping the worst case is a head gasket. I poured in a 50/50 mix that should keep things happy until the temps warm up around here. Pulled the plugs, sprayed fogging oil in the cylinders and spun the engine a bit in the hopes that that would circulate the coolant a bit. While the coolant was draining, I decided to ground out the generator, on the off chance that maybe it will still work one day. I went from the output stud to one of the cutout mounting screws, which I think should do the job. At some point I went inside and ordered a rebuild kit for the carburetor from Renners. Nice folks to talk to, and lots of knowledge. Lastly, I pulled some miscellaneous bits and pieces out of the trunk/rumble seat area. So far, I've identified the following: 2 battery hold down brackets 1 hand crank / lug wrench 2 door window anti-rattle strips 2 pieces of trim for the top 1 metal part that seems to go above the dash panel Not sure on the other bits. Any ideas? What is the bracket/hinge piece for? I also found the wood frame for the bottom of the seat. Yay! Another question I have is that the wood frame for the seat back doesn't seem to align properly with the L brackets at the bottom. The metal part that the L brackets are attached to seems to be loose, so perhaps it is not installed properly, or is just sitting there. I do have the tabs at the top of the frame slotted into the wood piece in front of the package shelf. Also got notice today that more parts for/from this car will be shipped to me shortly. Can't wait to see what arrives. |
02-21-2017, 12:15 AM | #29 |
You should see 3 holes in the header for the mirror bracket to attach to.
Do you have the dealer's parts catalogs? They can be a big help in matching up parts. |
02-21-2017, 12:42 AM | #30 | |
My father had collected some reference materials, and I'm waiting for them to arrive so I don't duplicate anything. The Bratton's catalog has been very helpful so far, and a few others are on their way. Thanks! |
02-26-2017, 08:57 PM | #31 |
Re: Intro & Questions - '29 Special Coupe
I've received a few boxes of various parts, both old and new. After a lot of searching through the Bratton's and Snyder's catalogs and websites, plus other vendors sites, I have some parts I can't identify. There is a good chance they don't even belong to this car. Any help identifying these would be greatly appreciated!
I don't have a parts book yet, and have been told that even they don't show images of all the parts. Can someone recommend one that does? Edited to remove two identified parts. Thanks to Tom and RJV. Last edited by cpf240; 02-26-2017 at 10:20 PM. |
02-26-2017, 09:51 PM | #32 |
The switch would be some aftermarket part for fog lights, electric fan, etc, or someone may have used it as an ignition switch if they didn't have to worry about theft.
02-26-2017, 10:02 PM | #33 | |
I'm looking at my options. I'd love to have it be original, but that looks expensive. For a occasional use, no show car, I think I'll target the middle of the road after market switches. I need to find a speedo as well, as it seems most places want a core, which I don't have. I'll check the ads here, and then maybe that evil auction site.. |
02-26-2017, 10:09 PM | #34 | |
Also, if you do buy one on eBay, count on it being only a core. The voice of experience talking here!
02-26-2017, 10:30 PM | #35 |
02-27-2017, 05:59 PM | #36 |
Picture #3 (top right in post #31) appears to be a rear spare tire carrier brace. See pictures about half way down in this link from Vince Falter's site:
http://www.fordgarage.com/pages/trunkconstruction.htm - |
02-27-2017, 06:22 PM | #37 | |
02-27-2017, 06:22 PM | #38 |
Picture number one has the two braces that go from the wood in the B pillar to the belt rail wood. I agree with Randy on picture number three. Picture number six might be an exhaust tip but not used on a Model A originally. The other items I do not recognize.
Dave |
02-27-2017, 07:02 PM | #39 | |
02-27-2017, 11:24 PM | #40 |
Pictures in #31, notice the hood bracket (anti-rattler) with the missing rubber in my picture.
