Old 07-31-2013, 02:53 PM   #1
usered
usered's Avatar
Default T5 adapter
Are there any other companies, besides Speedway that offer an adapter kit for a T5 transmission to a 59a (38) flathead using a hydraulic throw out bearing?
I'm having trouble getting good answers as if this is even possible.
usered is offline   Reply With Quote
Old 07-31-2013, 03:27 PM   #2
Tony, NY
Default Re: T5 adapter
I believe Krylon 32, on here, is Cornhuskers. They make a kit, but don't know about the hydraulic throw out bearing.
http://cornhuskerrodandcustom.net/Pages/Parts.aspx#
Tony, NY is offline   Reply With Quote
Old 07-31-2013, 03:47 PM   #3
37slantback
Gary at Cornhusker sells a hydraulic slave cylinder bracket and kit for the T5 as well.
37slantback is offline   Reply With Quote
Old 07-31-2013, 04:06 PM   #4
wspiker
wspiker's Avatar
Bob Drake has what you need.
www.bobdrake.com
wspiker is offline   Reply With Quote
Old 07-31-2013, 05:17 PM   #5
Ol' Ron
Ol' Ron's Avatar
depends on the T-5 all T-5's made after 92 have the Ford bolt pattern, they also have better ratios.
Old 07-31-2013, 06:50 PM   #6
Krylon32
I have kits for the 85-92 (Chevy Bolt pattern) and 93 up S-10 T5 trans (Ford bolt pattern). I also have a slave cylinder assembly that bolts to the side of the trans. keeps the hydraulic fluids on the outside of the bellhousing. Many times I can provide the parts to hook to your stock clutch linkage. Been selling these kits for almost 20 years. Call 402-749-1932 with questions. Gary at Cornhusker Rod And Custom
Krylon32 is offline   Reply With Quote
Old 08-01-2013, 11:58 AM   #7
ctaulbert
ctaulbert's Avatar
I can vouch for Gary's adapter kit. It's honestly everything you need to mate the T5 to your flathead.
I'm running a 85-92 trans with Gary's adapter kit, disk and pressure plate, as well as the slave cylinder assembly. I put over 6000 miles on the car last year, and continue to rack the miles up this year, with out any problems.
Cory Taulbert
ctaulbert is offline   Reply With Quote
Old 08-01-2013, 12:55 PM   #8
Jefscoupe
Jefscoupe's Avatar
I just got a steel bell from Quick-Time. I think they are a Lakewood company.
They have bellhousings to mate just about anything to anything.
SFI approved. Got mine for a late flathead to TKO 5 speed.
May have to get w/Gary about the hydro slave setup.
I'm a newbie here.
Jefscoupe is offline   Reply With Quote
Old 08-01-2013, 02:45 PM   #9
Pete
Pete's Avatar
Good answers are sometimes difficult to get and since no one has answered your question yet, I did a simple google search and came up with a couple hundred hits.
The answer to your question is, yes.
Here is one place to look.
http://compare.ebay.com/like/3605690...Types&var=sbar
