Old 10-18-2011, 05:14 PM   #1
Leon
Default Light switch rod - rattles to distraction
When I attach the light switch spider, spider spring and spider retainer on to the light switch rod, the horn button/light switch handle is flush with the top of the steering wheel. But when I attach the light switch body and bail, it pushes the light switch rod up so that the horn button/light switch sticks up about a quarter of an inch. Then when driving it starts to rattle and drives me crazy. What is the cause and is there a fix? This happened after having someone rebuild the steering box ( 2 Tooth on a 30 town sedan ).
Leon is offline   Reply With Quote
Old 10-18-2011, 06:23 PM   #2
700rpm
700rpm's Avatar
Default Re: Light switch rod - rattles to distraction
Light rods come in different lengths. Are you using the same one you used before the rebuild, or did you buy a new one? Do you have an early 30 with a 29 setup?
Old 10-18-2011, 06:45 PM   #3
Leon
Am using the same one that was on there before the rebuild. Everthing looks perfect before I put on the light switch body, - I even tried a different light switch body upper half but it made no difference.
Old 10-18-2011, 06:50 PM   #4
700rpm
700rpm's Avatar
Do the lights work when the rod pops up?
Old 10-18-2011, 09:49 PM   #5
Leon
Yes - horn & lights work.
Old 10-19-2011, 08:43 AM   #6
1931 flamingo
1931 flamingo's Avatar
Is there not a c-clip that's supposed to be in there somewhere?? CRS you know.
Paul in CT
