Old 03-24-2020, 08:30 PM   #1
cojones
cojones's Avatar
Default Correct carb for 33-34 pickup
Is it zenith or tillotson?
cojones is offline   Reply With Quote
Old 03-24-2020, 10:05 PM   #2
DavidG
DavidG's Avatar
Default Re: Correct carb for 33-34 pickup
Given the two you list, I assume that you are referring to the carburetor on a four-cylinder engine. If that's the case, it was a Zenith.
Old 03-25-2020, 03:00 PM   #3
cojones
cojones's Avatar
yes, thank you Dave
Old 03-25-2020, 06:47 PM   #4
Charlie Stephens
Also note it is not the same Zenith used on the Model A. It has an easy to see rectangular shaped float bowl while the float bowl on a Model A is round. Compare the gaskets in the vendor catalogs if you don't understand what I mean.
Charlie Stephens
