Old 08-14-2019, 08:49 AM   #1
manmerc5519
Default radiator for 55 merc with 302
Gentlemen I have a brand new radiator for my 53 but when I tried it in the 55 mercury the fan is too close any suggestions seems like I looking at the wrong places for radiators
manmerc5519 is offline   Reply With Quote
Old 08-14-2019, 12:08 PM   #2
KULTULZ
KULTULZ's Avatar
Question Re: radiator for 55 merc with 302
Does vendor cataloging call for the 53 to fit a 55?
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 08-14-2019, 02:43 PM   #3
scicala
scicala's Avatar
Default Re: radiator for 55 merc with 302
Probably because the '53 was a flathead V8 and the '55 is a 292 Y-Block OHV V8. Plus the '53 radiator will have two upper hoses and two lower hoses. '55 used one on top and one on the bottom. Can't see the '53 radiator working in a '55 at all.
Sal
scicala is offline   Reply With Quote
Old 08-16-2019, 11:32 AM   #4
manmerc5519
what radiator would I use for 302 in 55 mercury montclair
Old 08-16-2019, 01:03 PM   #5
dmsfrr
dmsfrr's Avatar
Does it fit well in the '55 Merc original radiator support?
Is the spacer between the pulley and fan too long?
Last edited by dmsfrr; 08-17-2019 at 10:36 AM. Reason: reading comprehension failure
Old 08-17-2019, 05:44 AM   #6
manmerc5519
yes I took the spacer out and it is still to long for the radiator from champion that I have
Old 08-17-2019, 06:22 AM   #7
KULTULZ
KULTULZ's Avatar
Post Re: radiator for 55 merc with 302
Originally Posted by manmerc5519 View Post
...what radiator would I use for 302 in 55 mercury montclair
It all depends on which Series 302/5.0L engine you have. Short and long WP and where intake is on bottom of WP.
No one sure answer.
- WHY IS IT ... -
Old 08-17-2019, 05:38 PM   #8
manmerc5519
it came out of a 1978 ford Granada with automatic tranny ,but it has been changed over to three on the floor
Old 08-17-2019, 08:31 PM   #9
KULTULZ
KULTULZ's Avatar
What you might want to do is call CHAMPION - https://www.championradiators.com/ - and get an idea. They will want some measurements I suppose and you have retained the original 55 MERC core support, correct?
- WHY IS IT ... -
Old 08-18-2019, 07:21 PM   #10
manmerc5519
Yes I have retained original core support
Old 08-19-2019, 04:31 AM   #11
JeffB2
JeffB2's Avatar
You can shorten up the 302 by about 3 1/2" by using the 1966-69 289 "short" water pump and harmonic balancer. Here is what is involved in detail. ( Read Post #5) https://www.jalopyjournal.com/forum/...ulleys.303600/ In 1952-56 Fords the 6 cylinder cars had the radiator further forward because of a difference in the lower sheet metal panels, since Mercury did not use the Six you have to get creative to move it forward which involves cutting the splash panel.
JeffB2 is offline   Reply With Quote
