Old 06-27-2012, 01:16 PM   #1
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Default 31 pickup rear window
We're working on a 31 closed cab pickup installing the rear window. I have never seen such an impossible task. We have 4 hours in it so far and only half the mounting screws and hex nuts in place. You would have to have fingers the size of spider legs to align the nuts and hold them behind the mounting flange then try to align a short screw and thread it into the nut. Ford must have had some fixturing to mount it on the assembly line, anyone have any suggestions ? Have tried several approaches, finally mounted ten screws I think out of twenty, mostly by luck. (Just frustrated)....
Barry B./ Ma. is offline   Reply With Quote
Old 06-27-2012, 01:57 PM   #2
Bill B
Bill B's Avatar
Default Re: 31 pickup rear window
I agree with what you said. My solution was to have a Corona and start again.
Bill B is offline   Reply With Quote
Old 06-27-2012, 02:38 PM   #3
Tom Mazz/CT
Tom Mazz/CT's Avatar
Try using a pair of forceps (spelling?) that a surgeon uses - They are like mini vise grips - I think that is what I used for the rear window install on my 30 CCPU.
Tom Mazz/CT is offline   Reply With Quote
Old 06-27-2012, 03:59 PM   #4
Clydes 31 P/U
Barry, These are what I use whenever my fingers get in my way. The screw starters are from NAPA years ago, the forceps I pick up at flea markets for a little of nothing so its no biggie to heat and bend them for certain jobs. Good Luck........Clyde
File Type: jpg helping fingers 001 (640x360) (620x349).jpg (91.9 KB, 14 views)
Clydes 31 P/U is offline   Reply With Quote
Old 06-27-2012, 05:35 PM   #5
ed thibodeau
I took a piece of metal that was 1/16 thick, bent it to 90 degrees and filed a notch in it to fit the nut and it worked fine as a wrench.
ed thibodeau is offline   Reply With Quote
Old 06-27-2012, 06:46 PM   #6
Barry B./ Ma.
Thanks guys, we finally got it in, my partner used a small needle nose pliers with the tips bent 90 degrees, very tricky and delicate operation. Whew, done.
