Old 06-16-2011, 07:08 PM   #1
CWPASADENA
CWPASADENA's Avatar
Default Model B Oil Pressure Question?
Hi Folks,
I have a stock "B" engine in my Tudor and want to install an Oil Pressure Gauge. What pressure range do I need? I know the Accessory Model A Gauges are mostly 0-10 Lbs. but the "B" should have a little higher oil pressure. I do not think a 10 Lb. gauge is enough.
What is recomended?
Thanks in advance,
Chris
CWPASADENA is offline   Reply With Quote
Old 06-16-2011, 09:26 PM   #2
James Rogers
James Rogers's Avatar
Default Re: Model B Oil Pressure Question?
10 is plenty. The B will run at 4-8 lbs normally.
