Old 08-22-2021, 08:29 AM   #1
russcc
Default 1948 side shift transmission complete
City: Bourne
State: MA
Price: in ad
Complete 899A- 1948 side shift transmission complete w/all gears. 28T cluster w/all of the gears on the cluster perfect, no wear or damage. Main driver gear, mainshaft and 2nd gear perfect, low/reverse slider has some mung on that I can't tell what it is, maybe caked on old gear lube. reverse idler fine. Transmission turns nicely in all gears. If you bought all good used gears like these from Ohio, you would be spending about $1,000. Complete trans.$585. plus shipping or p/up in SE Mass or Hershey. I will remove the gears from the case, clean them, replace the low/rev slider if needed and ship them to you in the USA for $750. See photos
russcc is offline   Reply With Quote
