07-24-2021, 10:33 AM | #1 |
Brake Pressure Bleeding
On my stock '40, when I pressure bleed the brakes I get one good long squirt out of the bleeder, then flow stops. Air pressure in the MC reservoir at +/- 9 psi goes down only a hair. If I pump the pedal once, then can get one more squirt.
So what am I doing wrong? With air pressure in the reservoir, pedal fully retracted, why does it not pressurize the lines and produce a continuous flow? (I believe the MC plunger does fully retract, brakes always fully release) |
07-24-2021, 10:42 AM | #2 |
Re: Brake Pressure Bleeding
Check the feed and equalizer ports out in the master cylinder for blockage.
07-24-2021, 09:11 PM | #3 |
ether a blocked port or over adjusted master pushrod [no free play] if you have free play and the port is clear a rebuild may be required as the internal spring may be damaged or weak /the piston maybe getting caught on a ridge and not fully returning
07-24-2021, 11:20 PM | #4 |
