06-24-2021, 03:29 PM | #1 |
PCV valve install question
So folks, I have this coming from JAMCO and got the install instructions down, I hope, but it says that this will raise the RPM's a tad....OK. So do I have to adjust the two screws on the carb or just idle her down a bit? Thanks as always.....
Don https://www.jamcosuspension.com/prod...ve-kit-pcv4953 |
06-24-2021, 04:48 PM | #2 |
Re: PCV valve install question
Both. This, I think, is the theory:
Adjusting the mixture screws will ad fuel to compensate for the little additional air coming in thru the PCV, to get the air/fuel ratio right. But then that additional air & fuel should increase the idle speed. So an adjustment to the idle speed will be needed. |
06-25-2021, 05:01 AM | #3 | |
Don |
06-25-2021, 05:30 PM | #4 |
